Air compressor question/gripe
>I'm putting a roof on for my cousin. (This may be the last roof I have in me, so I am not happy about it to start with.) I am using a Dewalt roofing nailer that we boughto install Hardiplank siding. We bought the nailer almost as a throw away and got the cheapest one we could find. (A good example of why you should not buy cheap)
My complaint is that the hot dog compressor we are using cuts on at 80 psi and off at about 120 psi. The gun really needs about 100 psi to nail reliably. 90 maybe, but 100 is better. Most of my big nailers are about the same. So, don't the gun makers and compressor makers talk to each other? Almost every compressor I have seen operates in a similar range. Doesn't do any good to set the hose pressure to a 100 if the tank falls below that. Am I missing something? Could I change the switch? Why don't compressors cut in at 100 and out at 140 or 130? I am really tired of hand driving those last four nails. My son calls it a nail starter.
Rant off, until I start nialing shingles again.
Re: Air compressor question/gripe
Chuck in ND
>Hi Barry, which compressor are you useing ? The way it sounds to me, your probably useing one thats too small. The compressor your useing may be better suited for smaller guns, such as a brad nailer, they don't have as large of an air cylinder for the plunger as a gun like your trying to use. And on a side note, I stay away from oilless guns and compressors.
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>Barry, I have increased the pressure on several compressors before. When you take the cover off the switch, you will find a screw with a spring around it. Tighten the nut over the spring to increase the pressure.
Make sure there is a pressure blow-out / release. If you increase the pressure too much, this will blow out rather than blowing up the tank.
You can then set the regulator to protect your gun at around 100 psi.
GalenV in Iowa
>Most small single stage air compressors are normally set at 80 to 100 psi. There is a small range the pressure switch can be adjusted but not always a good idea. They are really intended to work at the setting provided. Most compressor to reach the top pressure are running into the service factor of the motor. Try to run at a higher pressure or run for too long a time continuos and the motor will burn up.
To get the higher pressures for air tools it is a lot better to use a two stage air compressor with higher pressure settings and in turn will be higher horsepower.
Quincy compressors we used for years got cheaper construction. Good cast iron cylinders went to aluminum and all ran into the motor service factor to reach shut off. We had to ask for oversized motors in many cases so motor would not run into the service factor to meet customer spec and use.
Galen
Capacitor
Bill Howatt
>You may be able to somewhat reduce the effect of the low pressure setting assuming you have a long hose running to the roof from the compressor. Tee in a 5-10 gal portable air tank near the gun on the roof so it acts like a capacitor. This will reduce the pressure drop at the gun from the impedance of the long line and it will also give you a bigger reservoir of higher pressure air as a second benefit.
Bill
WARNING
Don Evans
>No one mentioned the upper limit of the compressor itself!!
The pressure switch has TWO settings, one is when it cuts off at the high pressure and one is when it starts up again, the low pressure.
Make sure you do not exceed the upper pressure the tanks and other parts are rated for, it should be marked on the plate.
Setting the lower pressure will just make the unit turn on more often than it normally would.
I'm guessing though that the unit you have is rated for 100 psi on the high end. Of course there is a safety margin but it will not give you that figure.
Don
Re: WARNING
Chuck in ND
>This is why I suggest to get an apropraiate sized compressor for the job, such as a portable twin tank or comparable in size. If your running several nailer you may need to go with an even larger air compressor. The original poster hasn't given sufficient information to know EXACTLY what he needs, but it does sound to me that what he has isn't enough. Messing with presure switches when you don't know what your doing can be EXTREMELY dangerous and I would not recommend it at all.
Chris Friesen
>I'm guessing the tank is too small, the hoses are too long, the hoses are too narrow, or some combination of the above.
Most nail guns should be just fine with 70-80 psi *at the tool*. The above factors combine to produce less pressure at the tool itself.
As has been mentioned already, teeing in an extra air tank near the tool would probably fix the problem.
Rick L
Re: Slow down...
Rick L
>or get a bigger compressor. Used to repair compressors and the roofers use twin tank compressors. In 30 years I've never heard anyone make such a complaint so it must be an operator thing.
Robby Wright
>Barry - Many pressure switches have two settings: The high pressure setting and the low pressure or differential setting. Take the cover off the pressure switch and see if you can find the low pressure differential adjustment. If you can, adjust it to raise the minimum pressure, leaving the upper pressure where it is so you don't damage something. If you start to hear the compressor cycling on and off too much, either slow down or use a bigger compressor.
Re: Slow down...
Andy Lincoln,in Dearborn,MI
>Rick,
Please explain to those of us who are clearly not as smart as you how slowing down will solve Barry's problem? If the nailgun will not fully set the nails when the pressure of the tank is below 100psi and the compressor doesn't cycle until the tank is at or below 80 psi what does speed have to do with it? Barry was not asking about the length of cycles,nor the frequency thereof.
I understand tone and inflection do not convey well via the written word on a message posting but in my opinion ,Rick ,you come off as condesending,holier than thou,with a know it all attitude.You can also reference the post above on the PlanoPress where you have interjected your opinion onto Fred's post.
I will apologize in advance to Ellis,the messageboard and the other moderators here and I fully understand if this gets deleted.
Thanks,
Andy
Rick L
Re: Simple problem solving
Rick L
>If the gun isn't setting the nails under 100 lbs then either he needs to slow down or get a bigger compressor. The other option is maybe the gun isn't working properly. Hard to tell from the info provided, but having spent a number of years repairing guns and compressors for professional roofers and others I've never heard this complaint. What would you think????
And yes I have had lots of panel glue up experience in factories and commercial shop and my home shop. Try the curved cauls and Plano and tell me why you think which method is better. Funny how folks try one thing and swear it's the best way. Ever used a Taylor rotating panel press. It's fast but the boards are no where in alignment so one runs them through the planer/widebelt. There are amny techniques to accomplish the same end. How many have tried them all or even know what all of them are. I don't claim to know everything but some things I can say I do know better than most. In 35 years you learn something, especially if you worked in many shops, talked to many people, and read all you could find. Don't see as many folks who read these days. They just jump on the web and ask "how do I do this?" There are only so many new questions out there and more folks asking the same old questions. Do you realize how many hobby forums are out there????? Sorry for the rant but am pretty much done answering questions on forums at this point. Don't think most questions have ever gotten that last definitive answer and am sure most folks wouldn't know that anyway.
80 PSI
>should, actually, get a roofing job done. After all, you're not driving into LVL or other engineered product. I've shot several roofs and used a light pancaker because of the ease; extension cord was lighter than air hose to move around with. I suggest you check your gun settings if it's leaving heads proud. If, by chance, you're bump-firing like many roofers do, your problem may be with gun recoil disengaging before the nail is fully set. That's a technique issue but I do know that some guys carry a hammer to fully set gunned nails from time-to-time, so you're not alone with the complaint.
You can get a new pressure-trol to vary the the compressor range, but it's not good to get outside the machine's range
