O.T.: Searching multiple locations in craigslist *LINK*
David Sparks
>I found this site and thought it might be useful. It allows you to select multiple craigslist locations when searching for stuff.
http://crazedlist.org/
David Sparks
Re: O.T.: Searching multiple locations in craigsli
Michael Bush
>Very cool site. I search multiple cities in Craigslist pretty regularly because I live about equal distance between three different metropolitan areas. Thanks for the link!
Alan in Little Washington (NC)
>Did Crazedlist fix it so you don't need to disable a feature (I don't remember which one) in your software? Multi-site Crazedlist searches weren't working for awhile because Craigslist made a change to block them.
I have been using a Google search instead. I use normal search terms followed by "site:Craigslist.org" (w/o quotes). The only problem with that is it will return expired listings as well as active ones.
Tates in Chesterfield, VA
>I like to search all of Craigslist at one time using Google. You can see all the country at one time. Here is an example to type in Google space: Delta DJ-20 site:craigslist.org
