Staining maple to match old rosewood?
Scott in Douglassville, PA
>Hi, all -
As part of the guitar rehab I'm doing, I'd like to color the maple headstock to match (or closely approximate the tone of) the rosewood fingerboard:
I need a dark field for a brass inlay I'm planning. I'm guessing stain will do it, but my samples all have splotchy coloring (go figure). So far, I've tried gel stain, gel stain over lacquer, solvent stain, and solvent stain after a mineral spirit washcoat. Nada. Zip. Zilcho.
Suggestions? I'm trying to avoid too much cost, FWIW - I have about 15 square inches to color, and spending $20 on a couple ounces of dye stain seems ludicrous...
Thanks,
Scott
Re: Staining maple to match old rosewood?
>But ludicrous is what it will take. That is a water soluble dye stain.
Clint
Yes. I Think That is True
Re: Staining maple to match old rosewood? *LINK*
Dan Donaldson
>How about ordering a rosewood peghead veneer and making it actual wood instead of a color? You can get them from many sources. The link is to one on ebay. (I just found this with a search and have no interest in it.)
peghead veneer.
>Now, that's an interesting idesa, Dan. I have a trip to Woodcraft coming up this afternoon - might pick up some veneer.
Question, though - how would you apply a 3/16" thick veneer to a curved headstock? Would there be enough flex in that thick a veneer?
Thanks for the suggestion.
Scott
applying veneer
Jesse Cloud
>Good question on the veneer. Only way to be sure is to try it before you glue it up. If it won't bend, take it to the planer and shave it slowly and carefully.
When you glue it up, best method would be a vacuum press, but if one isn't available, try lots of clamps and cauls. To be safe, leave it clamped overnight. Short of the really toxic stuff like Unibond, Titebond 3 is a good choice for glue.
Dan Donaldson
>3/16ths is too thick. You don't need more than 1/8th at most. how much curve do you have? I would think that thin veneer should bend a small amount OK. Here is a peghead with a rosewood veneer on it.
Veneer, plus nitro question...
>That's awesome, Dan. It's just the look I want. Did you do the MoP inlay?
I'll look for some veneer at Woodcraft today.
Side question for you: I'm at the finishing stage on this guitar. Was originally planning on using Deft spray lacquer as a sanding sealer and topcoat; I'm going to Woodcraft, and they have Behlen's nitro and vinyl sealer. I've read that the Behlen's yellows, and Deft doesn't, but that Deft can be hard to get to cure sufficiently.
Have any recommendation?
Thanks,
Scott
Re: Veneer, plus nitro question...
Dan Donaldson
>Thanks. I am attaching a picture of the whole front. I did all of the inlays. Combination of pearl and abalone. The rose was copied from a glass that we had and the fingerboard ones came from wallpaper and a bunch of other ideas. The stuff is interesting to cut, and you have to be very careful not to breathe the dust.
I don't remember the brand, but I used a high solids brushing lacquer to finish it. Don't have any experience with Deft.
Ok, 'nother question...
>First - beautiful bass. My hat's off to you, especially doing all the inlay work.
Now, looking at the headstock again, it looks like the rosewood veneer is inlaid into the headstock as well? Is the lighter colored wood just applied banding, or did you excavate a cavity for the rosewood? I really like that look, but was initially planning on just gluing the veneer into place with no edge treatment. Project spiraling out of control as I watch... ;-)
Any suggestions or guidance you have would be mucho appreciated.
Scott
Re: Ok, 'nother question...
Dan Donaldson
>The headstock, fingerboard, and body all have wooden binding on them. the body also has a herringbone inlay with bwb violin purfling. The headstock veneer was applied, then a groove cut around the edge and a maple piece was glued into it. The same with the fingerboard.
