Stair Treads
Doug
>Would the use of a good construction adhesive be a good way to secure wood stair treads to existing stair treads or should they be nailed instead? Thanks
Doug
Stair Treads
Doug
Doug
Re: Stair Treads
Ed Mulligan, Cape Cod
>Will the applied treads result in different riser heights? How thick is the new material? Building code may require less than 3/8" variation is riser height.
Re: Stair Treads
R. Gryder
>Doug,
I have used trim mark screws( the ones with the small heads) to attach stair treads. They hold really well and the little hole left is easy to fill and hide. R.
Re: Stair Treads
Jesper, Denmark
>In would think a bit of construction adhesive would stop them from squeeking and screws from the bottom would hold them in place while the adhesive sets.
