When does it ever end?
GolfSteve in Calgary
>1. I started woodworking wanting to carve (~1996).
2. I soon needed to learn how to properly build furniture so that I had something worth carving on. (~1997)
3. After some living room carving in, I had to build a workbench, so built a basic plywood bench.
4. I was dissatisfied with the noise, dust, and relative inaccuracy of my cheap power tools and began the leap into the quiet side of hand tools. (~1998)
5. I learned how to execute hand-tool joinery, dimension raw lumber, and produce hand-planed surfaces (1998-onwards)
6. I learned that my benchtop tablesaw and bandsaws were garbage and invested in better and quieter power tools. (1998-onwards)
7. I was limited by the basic oil/danish oil/poly finishes and decided to learn French polishing. (~2000)
8. After becoming disappointed with the longevity of French polish (perhaps due to my poor technique), and frustrated by how long it took to apply a good quality finish, I decided to learn spray finishing (still learning�) (~2004)
9. My old plywood bench was not well suited to hand tool work, so I spent a long time building a cabinet makers bench (2006)
10. I had a baby and and became dissatisfied with how long it takes me to make anything, especially when I mostly use hand tools except for rough work. (~2006)
11. I bought a lathe to add round things to my work�but then I needed to learn how to turn. (~2006)
12. I set out to improve my power tools (ie. tablesaw) so that faster, more accurate work can be produced direclty off the machine and I don't need to use hand tools as much to improve the power tool cuts. (~2009) Maybe a powered jointer is in my future, but there's no room for such a time-saving device.
13. Now I need to buy a house with a large dedicated shop so that I can install a finishing room and have room for a powered jointer�.it never ends :-)
Someday I'll get to a point where I can a) make good furniture, b) put a good finish on it, and c) complete my list of backlogged projects so that I can get around to designing a project that incorporates carving, d) then learn how to carve faster and better, e) enjoy using both power and hand tools (I'm getting there), and f) be fast enough to make more than one piece in my lifetime.
Still learning�and hoping there's not much more to learn so that I get more done.
Re: When does it ever end?
And Now For The A-N-S-W-E-R . . . .
>How do you carve faster?
Easy
Get a bigger hammer
Jim Shaver - Oakville, Ont, Canada
>And..........
when was the last game of golf you played?
For me it was in 2003 at Glen Abby ( to think I was once a 10 handicap...sigh, now it's wood that is my handicap).
Take care,
Jim
Too bad...
doug f, san clemente, ca
>I think you're going to find that the more you learn and the more you can do, the more you'll want to learn. It's a never ending cycle; but, damn, is it ever fun!
Doug
mike from american sycamore
>I met a man at a woodworking show once and I started to tell him about my school. He told me that he knew everything about woodworking and my school could not possibly teach him anything that he did not all ready know and that he was an expert in everything!
If I ever get that way I hope to have the sense to put a bullitt in my head!
I am learning everyday and still continue to learn. My students are my best teachers. My students come from all walks of life, some doctors, some lawyers, even an Indiana chief. They all approach a problem from a different angle and can teach me a better or quicker way. Life is good! Keep on learning!
thanks,
Mike
>I hope I never stop learning, I'm always trying something new on each project and I've been on the steep part of the learning curve. It would be nice to just fire out a couple projects instead of agonizing over some new task.
I need a bit more repetition to "set" the skills I've picked up, to make those skills second nature instead of something where I have to think about each move.
Cheers,
Steven
>I started with a Jigsaw, router and handsaw. Built a tilt up workbench that locked in the closed position because my garage didn't have a door and only had a stone floor.
Now I have 2 car garage with 4 wood lathes, a metal lathe, bandsaw, metal cutting saw, table saw, jointer, planer, radial arm saw, miter saw, more clamps than most hardware stores have for sale, 10 or more handplanes, router table, portable forge, anvil and 2 welders, Disc sander and 2 strip sanders, 3 grinders, drill press, Shaving horse, I don't even know how many hand power tools, like routers, drills, flex shaft machines, angle grinders etc. well you get the picture. If your hung up on learning new techniques, it never ends.
I'm Surprised you got past #11!!!
Scott Greaves in Blackfoot Idaho
>Learning to turn is usually a black hole you never escape from! Conrratulations! ;-)
Scott.
Jim Dillon
>Stephen,
But then it wouldn't be fun anymore!! Your list is a good one that made me chuckle and reminisce back to 1995 when my better half suggested I needed a "program" to fill my retirement years. I briefly tried astronomy, but had trouble staying awake past 8PM, especially after a drink or two or... . What about woodworking I thought? Don't need much: a Skilsaw, some sandpaper, and maybe something fancy like a router. Geeze, if I only knew what I was getting into. A bit of off-topic advice here: don't ever take up digital photography - it is also a bottomless money pit, with another endless learning curve; but so much fun as well!
Thanks for posting such a great list of your, dare I say, endless journey.
Jim
Marv....... Northern California Lake Co.
>If you are having fun, just hope it never ends.
However, should you ever come to what you might consider the end, try teaching others what you have learned. Teaching others how to do what you can do is perhaps even more rewarding than doing it all yourself while tucked away, all alone in the bowels of your shop.
Marv
It doesn't
Bill Tindall, E.TN
>You seem to be a dedicated woodworker. Hence, the quality and complexity of what you want to build will always be a stretch beyond where you are at. About the time you get all the stuff made you want, your children will be pestering you to make stuff for them.
I remember your write up about your work bench
Victor Parisian
>Very nicely done. I saved it and look at it from time to time. You do inspire some of us. To paraphrase Jack Nicholson "You make me want to be a better woodworker."
Enjoy the journey.
Regards from Hot and Humid Houston
Victor
