ADVERTISE HERE - FREE TRIAL
Any help on how to repair a deep gouge in table?
Juliet Robinson
>I bought a beautiful dark wood dining table and it has a few deep scratches/gouges that occurred while the previous owner was moving it in storage. Looks almost like a nail or something sharp got rubbed against it.
I'd like to repair it as much as possible but not sure what my options are. I was thinking of trying to fill it with one of those crayon-looking wood fillers, and trying to find a dark one that would match the stain. I just don't want to make it worse, or mess up future restoration by doing this.
Any thoughts?
Thanks much!
Re: Any help on how to repair a deep gouge in table?
Re: Any help on how to repair a deep gouge in tabl *LINK*
waroland
>This is made fro hardwood floors but you can achive almost any color by mixing colors.
Repair Kit
Brian Anderson
>It is not clear from your post if the fibers of the wood are broken.
Did the nail cut or merely crush the fibers.
If the are broken, then filling is most likely necessary.
BUT if the fibers are not broken but pressed as in dents then the fibers may be able to be raised.
Of course refinishing is a very strong likelihood.
If the wood fibers are crushed but not broken steam and wet heat can raise them.
Good luck.
Brian.
Ed Mulligan, Cape Cod
>If you're able to post a clear close-up photo it would help.
I don't think colored wax would be suitable for a table top. It's not durable.
If the top is veneered it will be difficult to refinish without causing more damage. Modern veneers are quite thin. The chance of sanding through is high.
If you do decide to undertake this repair, I'd recommend practicing on a junk piece until you like your results.
I agree
>If the top is veneer, as Ed asked, any deep gouge will most certainly be through the veneer. In that case, water-based wood filler is my recommendation. Try not to fill it too much. A credit card makes a good squeegie to skim it off level with the wood. When it's dry, give it a light sanding with 220-grit dri-lube (stearated) sandpaper wrapped around a flat block of wood. Then touch up the color to match the surrounding wood using dry pigments and shellac or lacquer and a tiny sable paintbrush. Finish up with a spray coat of clear lacquer or varnish, whichever will match the surface sheen of the rest of the table.
My 2�,
Ellis Walentine, Host
