OT Mortar Mix
OT Mortar Mix
OT Mortar Mix
Sawman
>I need to lay up some brick on my chimney. WWhat is the correct ratio of sand and mortar?
Thanks!
Re: OT Mortar Mix
Lee Grindinger
proportions
Lee Grindinger
>I think you're making mortar which is cement, lime and sand. 3 parts sand, one part Portland cement and 1/2 to 1 part lime. Lime makes it set up quicker so use 1/2 part if you're slow.
Masonry sand will finish bettor than regular washed sand. If appearance is important use masonry sand which is finer. If appearance is not important use washed sand, it's cheaper.
Lee
Re: OT Mortar Mix
Re: OT Mortar Mix
GalenV in Iowa
>You can just buy QUICKRETE motar mix or mason mix. QUICKCRETE vinyl concrete patch can be used for better adhesion.
If you are worried about matching then you need to find someone who can determine what mix was used for original chimney.
Re: OT Mortar Mix
Re: OT Mortar Mix
>I agree with the others. If you are doing a small job you might try premixed mortar. Read the bag carefully and make sure it has the sand already in it and you are not buying just mortar.
Lee is right about the lime. Way back mortar was just lime and sand, but newer mortar has cement as the dominate binder. Lime makes the mix plastic or sticky and easier to handle. Cement makes it stronger and more brittle. Cement mortar does not stick to the trowel or brick as readily and tends to be hateful to use. It falls off the trowel or brick easily.
Matching the existing mortar is an art and if its really important can require finding matching sand and then matching the mix accurately. I would suggest a little test. Mix up a small amount of whatever you intend to use and let it set for a few days. It drys lighter. To my eye, light colored repairs look like terrible scars and really scream. You can buy colored mortar and you can buy coloring agents to tint it. I would darken it a bit. Slightly too dark looks much better than too light and weathers in better over time. Even the borgs have some tints now and a masonry supply house would have a lot.
Re: OT Mortar Mix
Re: OT Mortar Mix
Fred Davis
>To improve the handling qualities of Mortar, Union trained Masons in this country and guilds in Europe, add small amounts of Fire Clay to the mix to make it "buttery" and easy to apply .
For a 60 Lb. bag of premixed mortar , a double handful will be about right , much more then that and it will weaken the mortar.
Construction size wheel barrow loads of mortar , would use about a round point shovel load of Fire Clay to the mix.
Coloring agents like Aluminum Oxide go a long way in small amounts and over doing these can also weaken a mix.
Likewise , colored tile grout is not as strong as the natural cement colored, which is why hardly anyone tries to mix their own, but buys premixed grout instead.
Portland Cement has been a constituent of Mortar for as long as I have been around it or used it.
FredD
Re: OT Mortar Mix
Good tip, never knew that one...
John in NM
>But I did once get a small load of 3/4" plant mix for concrete that had enough clay in it to make it sticky - and probably weaker.
I've also added vermiculite to lime plaster to make it lighter, with the convenient side effect of making it stickier and giving it a much more workable body.
Personally I avoid premixed mortars like the plague. I'm a slow mason, usually using stone rather than brick or block, so the premixed stuff sets way too fast for my tastes. I believe they add CaCl or some similar salt to accelerate the curing.
