We value your privacy.
>I have some thin heart pine (mostly less than 1/2") that I want to use in some building projects. I really need thicker wood, so I was thinking of laminating it to some 1/2" plywood and then planing the heart pine side back to 3/4". Have any of you ever done this? If so, what type of glue did you use? Any tips?
>When you said the "heart pine side," I realized you intend to add the heart pine to only one face of the plywood. I strongly advise you not to do this. If you want, you can add the heart pine to both sides of the plywood to balance the construction. I haven't glued a lot of heart pine in my day, but I recall having luck with regular yellow glue.
>Yes, but it is a bit more than that. If you laminate only one side of a piece of plywood, it is very likely to cup severely. Veneer on both sides balances the forces.
>If you used solid wood instead of plywood you could have the same problem due to the woods not moving at the same rate. Best to balance it out with an equal amount of wood on both sides.
>Plywood and other dimensionally stable substrates (MDF, novaply, flakeboard, etc.) essentially don't move in any dimension. Solid wood moves in the radial and tangential dimensions (every way except lengthwise). If you glue a piece of solid wood to a piece of plywood, you can expect the lamination to cup as the moisture content of the solid wood piece changes from season to season.
The way around this is to glue thin stock to *both* sides of the substrate, so the cupping forces are equalized. Standard thin veneers and thicker (up to 1/10" or so) sawn veneers may be glued to man-made substrates without too much danger of cupping, warping or checking problems, depending on the species. At some point with each species, you cross a threshold where the thickness will cause the veneer to behave more like solid wood. To be on the safe side, it would help to run some tests with the approximate width of layup you intend to do.
