OT--Truck repair help
Joanne in Pt. Pleasant, PA
>I bought an old truck for weekend projects, hauling "stuff", and a myriad of other general uses so I don't trash my little Subaru. It's already been immensely helpful to have. It is a 1998 Ford Ranger 5- speed. Runs great, has low mileage for its age, no rust, looks fine, was never in an accident or had a driver who smoked. The only issue it seems to have is when I tilt the wheel towards me, the turn signals do not work. The high beams and wipers do (all 3 on the same stick on the steering column), but not the turn signals. Pulled the dash apart to look--no loose or crimped wire that I can see. Sprayed WD-40 on the tilt gears or relays (tilt works very smoothly now!). But signals still only work when wheel is tilted furthest away from driver.
Any ideas? Is there a switch I can replace or a wire being pulled that I have to trace? Thanks in advance for your experience/knowledge.
Re: OT--Truck repair help
Dale Lenz
Dale Lenz
>Ask my son who is a Certified Ford Mech., Josh. Josh said that's a common problem with that age of trucks, in short you need another wiring harness that goes to your turn-signals. Josh said that there are ways around to quick fix, such as zip-ties but he does not recommend Southern fixes, : ' >, fix it right and be done with it. New wiring harness from dealer, about 50 dollars. It also takes a special anti-theft torque screw driver to get into the steering column guts.
Shade tree fix.
Basil
>Used to be able to buy a turn signal box that clamped to the steering column. They were standard equipment from the factory on a lot of larger over the road trucks many years ago. They were called a "Signal-Stat" if I remember correctly.
If you could locate the proper wires under the dash, all you'd have to do would be to connect them to the "Signal-Stat".....just one little drawback tho.....you have to return them to the 'off' position manually.
I stuck my arm out the window at school the other day and my son, who's at that "please don't embarrass me, I'm only 14 age", wanted to know what I was doing. I was giving a hand signal because it looked like the driver behind wasn't paying attention. Am I the only one left in the world that knows their hand signals? Do they still teach those or require you to know them?......god I'm feeling old because I remember when "all" cars and trucks didn't have signal lights.... a lot of them back then had only one small taillight..
Dale Lenz
Re: What I'd probably do.
Dale Lenz
>Go to a Ford garage or any garage and see if I could borrow their torque driver, remove screw and go home remove the other standard screw 3 or so according to my son. Zip-tie the sucker well, test, replace screws, go back to garage tighten torque screw and give the mech. a soft drink and remember him next time I need work done on my car/truck. If it malfunctions again, spend the 50 bucks!
OT story
>I used to have a 1949 truck (Studebaker - son has it now) with one taillight. I got a fixit ticket for something or other one winter, so close to my house I parked out front; the officer invited me in to sit in his patrol unit while he wrote it up. He had a checklist of items, got to the taillight, was about to write me up when I gently pointed out that one taillight was legal in that year; next question, "were you wearing your seat belt?" He said to himself, no, not required; I said, "Yes, I sure was." Left him him a little confused...
Lee Schierer - McKean, PA
>I agree with Dale, the best fix is a new harness. I had a similar problem with the remote mirros on my 95 Ford Explorer. The left mirror (drivers side) would not work left to right. What I discovered was one wire had broken in the harness where it went from the body to the door. I was lucky when I opened the bundle that eh broken wire was right on top and easy to identify. I was able to slip on a piece of small shrink tubing and splice in a short piece of similar wire to fix mine.
Most likely your harnes has worn through the insulation at some point where the harness rubs on part of the frame. Finding it could be an adventure in itself, fixing it in place may require a small elf to get into the impossibly smal space where the work will need to be done.
Lee
You are joking, right?
Mark Nowicki
Dale Lenz
Re: Why would I be joking
Dale Lenz
>According to my son, he has done it and as far as he knows it's still working. His recommendation is to change out the harness, fix it right as he said. You might get away with it, I'd say it's worth a try. Could be a bare wire also as another poster stated, elect. tape would then work. This ain't the space-shuttle, : ' >.
Jim DeLaney, Austintown, Ohio
Re: Why not
>Just go to Harbor Freight and buy the whole set of 'security drivers' for about five bucks?
Jim D.
Re: OT--Truck repair - SAFETY NOTE
>This truck is new enough to have an airbag. Be sure you know what you're doing before you attempt disassembling the steering column. Setting the air bag off accidently could ruin your whole day/life.
Jim D.
Re: Shade tree fix. & "hand signals"
Ray Newman
>I think the only hand signal people understand & know these days is the middle finger fully extended w/ the other fingers folded down....
Re: OT--Truck repair help *LINK*
mark nowicki
>Joanne:
I am currently fighting with my F150 and this site has been of great help. Ford being Ford, it is likely that someone else had experienced a similar problem,
Mark
Ford Forums
mark nowicki
>Personally, I would not have the courage to walk into a place of business and ask to borrow a tool in exchange for a soft drink.
Mark
Dale Lenz
Re: Maybe just...
Dale Lenz
>different parts of the county(?). I was raised in the city, live in rural now. Our Home Town, Ann Bee-of Andy Griffin, : ' >, I know a few of the Auto Mech. around town (from paying jobs) and would not hesitate to go ask.
Re: OT--Wow!
>Thanks, everybody. I've looked online for parts. I only see "turn signal switch" for that area of the truck. I do not see wiring harness--other than what looks like it is for stringing the whole length of the truck to the back for a hitch. Is that it? Is there one big length of wires that goes everywhere?
As it turns out, I happen to have Torx drivers and have already pulled off the column cover, so I don't need to go borrow or buy them.
Jim--thanks for the warning about the air bag! I didn't even think of that. There IS one there. If I go to a dealer to ask about a part, I'll remember to ask about steering clear of that. I always hated when bubblegum would pop in my face; I can't imagine an airbag doing that.
Local library
>You might stop down to your local library and ask the reference librarian if they have the Motor (better) or Chilton (not as good) manuals for that truck and year, or, better yet, a truck-specific manual. The Motor/Chilton manuals cover all the cars for a year range, and are pretty sketchy on any given procedure on any given vehicle. Some library systems still have the resources to have an array of manuals available (not necessarily the same day, but quicklike). Reading through the steps/hints can help a lot; at the least, I would expect them to have directions on disabling the air bag.
Re: Local library
>Thanks, Bill. That's a great idea!
Re: OT--Wow!
Bob Entwisle in NJ
>Sent you an email,
Bob
AZ, Colorado Springs
>I asked to borrow a torx driver so I could change the seats on my old Jeep. They refused to loan out a tool.
The mechanics each own their own tools. If you knew the guy you were borrowing from, that'd be different. But then, you would've said you were borrowing from a friend.
Sso, I went to the Napa and bought the torx bit I needed. (There was no harbor freight store nearby.)
