Griz wheel locks . . .
steve mackay
>I've tried and tried to come up with a gripe about my Grizzly. Finally found it today running long daddos. Yes, I understand the engineering behind the wheel lock knobs to stop the adjustment but it takes two hands.One to hold either the blade or wheel and the other to turn the knob. With one hand holding either my sample or ruler to the blade, when I turn the lock knob it turns the wheel and moves the blade. Since I know there is a Grizzly rep lurking here at WC I'm sure they'll be happy to send me their new, super-secret, one-handed, cam / lever adjustement wheel lock to test out in my shop. Thanks guys, I'm looking forward to hearing from 'Ya !
Re: Griz wheel locks . . .
[Psssst Steve]
>Like most every saw I've ever owned or used, you set the elevation / tilt, then, while holding the elevator/tilt wheel with one hand, you tighten the lock knob with the other hand.
'Tis the nature of the jam-nut + collet locking knob, I think.
Alas, I can still dream . . .
steve mackay
>As Bruce Willis said "They've got a bunch of pepole siting around just think'n stuff up."
Chuck in ND
>Thats and interesting idea Steve, Om my Delta Contractor's saw when I hold the wheel with one hand and turn the center locking knob with the other hand the blade height does change some so, I have to keep an eye on it, a cam lock maybe would solve that problem or atleast lessen it some. I can kind of see where your comeing from, but I'd have to look at my saw to see how workable that idea would be. I do know that I could possibly help you improve the dust collection on your saw though.
Re: One more thing
Chuck in ND
>I'm not a Grizzly Rep, but I did stay at a Holiday Inn Express. (-:
Re: What I do..
Brian in Brighton
>If I have a dado cut like you are speaking of, I do the adjusting a little different. I set the blade just a little high, maybe 1/64 or so. Mostly tighten the locking knob while holding the adjusting knob. Now using one hand to lower the blade and the other to check the height. Get it set. Tighten the lock nut tight. This loads the screw, but if it moves during the cut the blade only goes down, so I can reset and run again after checking my dado. I have a Delta contractors saw but have not had it move more than a couple of thousandths in depth, so it was no big deal since that could be due to the wood, or me pushing.
This works for me, but a quick lock would be nicer.
Brian in Brighton
Re: I give up.
Chuck in ND
>I really don't know why I care anymore. I guess I'm just an idiot.
