Has This Paint Gone Bad?
Steve in East Tennessee
>I have a 1-gallon can of Sherwin-Williams satin interior alkyd enamel that I purchased several years ago while refinishing a room. I use it on all the architectural pieces in the room, as the builder used a gloss latex on these, and the appearance is dreadful. The alkyd enamel has served me well in the past, as it flows well, and brushes nicely, leaving a substantially durable finish.
Well, I started another room, and I had what I thought to be enough of this paint to finish the room, so I gave it a go. The can was about half-full, and there was a hard film on the surface, easily removed. But 48 hours after I painted the molding, the surface is still tacky. I don't ever recall this paint to take this long to dry. It does take some time to cure, but usually it is dry to the touch in 12 hours or so. Is this stuff ever going to dry, or am I going to have to try and remove it and go with a fresher batch? I can't remember this ever happening to the Sherwin-Williams enamels, but they are forever tinkering with their formulations, and perhaps the shelf life is no longer measured in years.
Re: Has This Paint Gone Bad?
Re: Has This Paint Gone Bad? *LINK*
>Oil paints do have a shelf life. From what you describe, it sounds like it's gotten old.
I recommend calling Sherwin-Williams, with the can at hand, in case there's a date code on it.
http://www.sherwin-williams.com/contact/index.jsp
Dale Lenz
Dale Lenz
>Steve,
Before I'd consider giving up the ship, I'd try to lower the humidity in that room, heat is the easiest way, think space heater(s), would not think oil base paint is that flammable. Would not move much air as in fans as you could get some dust sticking to your un-cured paint. E. Tenn. has been getting a lot of rain recently, if I'm guessing correctly. The humidity and temps here in E. Okla. has been not the best drying conditions for oil base finishes.
Good luck
Howard Acheson
>If the can was half empty, over a year old and had formed a skin, it is telling you to replace it. Finishes are not a place economize. At the very least, test the finish by applying it to a small area or a test piece to see if it dries normally. If it doesn't you have final confirmation that it needs to be replaced.
At this point, I would not expect it to dry properly or thoroughly. Paint, like any oil based finish, dries in two steps. First the thinner evaporates and then the finish goes through an oxidation process. Oxygen mixes with the paint causing it to get hard and develop full adhesion. What happens with oil paint, particularly if the can has been opened is that oxidation has progressed. There is no way to re-constitute old paint.
You can try waiting a while longer. Keep testing by pressing your fingernail into it. If it leaves an indentation or if you can scrape it off with your fingernail, you are going to have to remove the paint. Probably the best way is with a chemical paint remover. Of course, this will also remove the prior coats.
Good Call
>I believe this paint has exceeded its shelf life. Fortunately, the majority of the work has been crown moulding. But door thresholds are still tacky after five days of "cure" time. The original spec said it would be dry to the touch in four hours, and able to accept a second coat after twelve hours. This is not going to happen. But it seems a bit less tacky each day, so perhaps the crown will cure, and I can strip the threshold with OMS. That would be a lot easier than scraping and sanding.
I'm 0-for-2 in the finishing department this month. I figure dumb luck is on my side for my next project.
