The Projects Within a Project
Jim Shaver - Oakville, Ont
>¤t
Or is that The Battles Within the War?
Well my weekend Update on the kitchen...
Just kidding, I am finding out as I work through my kitchen renovation that there are more projects within this one that could stand alone as a project with all the same feelings of accomplishment when they are done.
Through this epic I have worked on three bathrooms and a laundry room during the Make Over of the house and I have not spent more time on any one step than the worrying about some changes I had to make in the kitchen. Here are my results.
One change that I had long wanted was to open up counter space by moving the microwave to above the stove. The existing cabinet was too tall to allow such a change to be made; it needed to be cut down from over 18 inches tall to 12 inches. That was simple enough, make a new box and doors. But the doors had to match the colour and the design of the existing doors. Such has been my anxiety for a few years looking at this. What could be the hardest part of the change, making an arched top was my worry, never having made them and thus a new learning from the process. But wait, there had to be a way for me to size the old doors and reuse them to make new ones, worst case use them as a template if I needed to go from scratch.
So I decided to see if I could re use them, careful cuts at the table saw and some careful disassembly was my key.
First I carefully cut the lower rail free from the doors, tapping the small stiles with a hammer I was able to cleanly break the cope and stick glue joints.
With some clean up work with a chisel I was able to clean the rail cope and then dry fit them back in to the doors, a super fit!
I then tapped out the raised panel, it was easy to do, but I found the panel had been centre set with two tint pin nails, my metal detector came in very handy and my careful extraction would be to the envy of any dentist watching me.
Once the panel was out it was simply to resize the length of the panel then route a cove that matched the rest of the panel and then reassemble the doors.
With the doors assembled and stain matched, I assembled them back to the cabinet and dry fit the box back in its place above the stove.
So far so good!
My other project was to make the door for the blind corner cabinet pull out hardware,
Jason was right, I will be going handle less on the sink base, the slide out will hit the existing handles, but I have a Plan B.
My next steps are to make two drawers with hand cut dovetails of course. I am excited as well; I am using the soft close Blum Tandem sliders, how fun, eh!!
Take care,
Jim
