Everything I like about steamed walnut
Michael Bush
(chirp, chirp, chirp)
I understand why they do it, but you could say it makes the heart look almost as much like sap as they other way around.
I'm making two of the Newport easy chair in Norman Vandal's book on Queen Anne furniture. Over the weekend, I assembled the backs and fronts. The difference in color between the rear leg posts (make of steamed stuff I bought) and everything else (made of wood I cut on my father-in-law's farm) is huge. I anticipate a headache getting them to match when I start putting on a finish.
In the future I guess I'll have to adopt Vandal's approach and use mahogany, cherry, or maple if I can't get enough unsteamed walnut the right size.
------WebKitFormBoundarynTwXtY74338h2+xC
Re: Everything I like about steamed walnut
Lee Grindinger
Steamed vs non steamed
Lee Grindinger
>The late and great Jon Arno and I went around and around on this one.
I used to operate two low temperature lumber drying kilns in upstate New York. I dried a lot of walnut, never steaming it. I'm also a retired furniture maker having used thousands of board feet of steamed walnut. My point is that I have a bit of experience with both.
For most work I preferred steamed. While the colors in non steamed low temperature dried walnut are bright, vivid and beautiful they are transient. UV light dulls these colors relatively quickly depending on it's exposure levels. Do this test yourself, take a vividly colored scrap of non steamed and put it in the direct sun for a few days.
Steamed walnut for me did not make the sapwood usable, it made matching the heartwood easier. Matching the heartwood in unsteamed requires a lot of attention and is quite challenging in large projects using several hundred board feet of lumber. It's a piece of cake in smaller projects using only a few boards but large projects present real problems. I liked the uniform appearance of steamed walnut for many applications.
Your challenge has been created by mixing the two, I'm guessing you didn't have enough unsteamed walnut to do the job and filled in with steamed. The problem you may encounter down the road is that the unsteamed portions of your project will lighten while the stained-to-match portions will not. Consider finding some unsteamed lumber for your needs, Woodfinder can provide you with plenty of options and it may just save you a lot of disappointment and aggravation come finish time.
Oh, and Jon finally conceded to this hot box jockey on this issue,
Lee
Re: Steamed vs non steamed
Don Orr
>Thanks for the info Lee.
Where in Upstate NY were you ? I've lived in Central NY and Capital Region most of my life except for a few years out West.
Lee Grindinger
Woodstock/Saugerties/Palenville
Lee Grindinger
>We lived in Woodstock, my first shop was in Saugerties. We later moved to Palenville into an old cafe named the "Cook Nook", converted it to a workshop and lived in the back.
One of the great treats in my travels was being one of the first to enter the rear staircase of the Albany capitol building after the restoration. It is stone carving at it's very best! If you haven't seen it yet get over there, it's an acanthus vine motif but "hidden" in the carvings are likenesses of workers, mythical beasts, pets and family. We left the area in 89 or so, we were back there years later and I stumbled into the capitol building in my study of ornamentation and architecture, I spent two days in that staircase and I think the staff was beginning to think I was a homeless guy looking for a heated space under the guise of a tourist.
Lee
rebuttal repost
Bill Tindall, E.TN
>A piece of fresh cut walnut was split and one half steamed and the other not. Each piece was then air dried and exposed to sun in a southwest facing room for 3 summer months. Upon close examination I can still see some difference.
The walnut colors that some find desirable are fleeting if the wood is exposed to the sun and air.
After you are done making the chair set it in a sunny spot and soon it will all look the same. Leave it there long enough and it will be as light as ash exposed the same. For this reason I always stain walnut with a pigment stain.
Upstate indeed!
Bill Tindall, E.TN
>It is well established that upstate begins at the Mohawk valley, or some would claim Rt 20. .
Lee Grindinger
Unless...,
Lee Grindinger
>Unless you're one of the 8 million people who line in NYC, for them upstate begins around Mt Kisco/Bedford. Heh, heh, he...
Most of my site work for architectural jobs was in the burbs on NYC.
Out of sunlight, though..
Michael Bush
>...it doesn't change that much.
I've got a stool I made twenty or so years ago that is still pretty close to the original color. It lives below the level of the windows and just doesn't get hit with direct sunlight that much.
The same is going to be true for the undercarriages of these chairs. I assume they'll be very close to the color they are when they leave the shop for a long time to come.
------WebKitFormBoundaryPBASp+zGk3duDAw5
Heck, That's downstate to me ;-))
Don Orr
>Real nice area though.
And you are right about the Capital. Have you seen it since the staircase was cleaned ? Amazing!
