Router speed and speed control Q's
Ed Wujciak
>I usually hang out in the turning area, but I'm trying to use my router (for the first time in years) and I'm having a problem and I hope someone here can advise. I'm using a 3/16 roundover bit on some cherry. Works fine with the grain, but burns badly when I rout across the end grain. It's a fairly new carbide bit. My router is an older single-speed beast (25K rpm nominal). I seem to remember reading that slowing the router would help. Is this true? I do not have an outboard speed control BUT I do have an old Variac which actually gives me the ability to lower the voltage which will certainly lower the RPM's. Can I use this for a speed control or will I damage the motor? Experiences and/or opinions please. thanks
