Stains
Stains
Stains
Gfriend
>Would like to know when it comes to staining wood of any kind..what is the preferred stain...oilbase or water. Thoughts on alcohol soluble dyes?
Re: Stains
Re: Stains
Fred Davis
>G,
I would highly recommend getting a copy of "Understanding Wood Finishing" by Bob Flexner who regularly writes a finish column for WoodShop News.
This will eliminate many errors and misunderstandings and get you on the road to a happy ending.
FredD
Re: Stains
Re: Stains
>You said: "Would like to know when it comes to staining wood of any kind..what is the preferred stain...oilbase or water. Thoughts on alcohol soluble dyes?"
Too many variables. Different woods stain better with different stains - that's why there are so many types. It also depends on what sort effect you are trying for. Look for staining and finishing books by Jeff Jewitt or Michael Dresdner.
If I'm staining poplar or soft maple, I like using a gel stain. I like using water based stains in my basement because they don't have a strong solvent odor. I like using alcohol soluble dyes (with suitable retarders) when I'm staining a chair because I often have several different types of woods.
Re: Stains
Re: Stains
Dick Coers
>For ease of application, oil based is hands down the choice. Water and alcohol base require you to flood the surface to limit overlap marks. Oil based stains usually have dye and pigments. In my opinion, water based stains can look a bit "muddy", and don't give the depth to the wood. There are so many choices, and brands, I imagine most of my comments can be negated. Just sharing my experiences.
Re: Stains
retarders question
Bill Tindall, E.TN
>You mentioned the use of retarders for dye stains. What do you use?
Re: Stains
Re: retarders question
>I've used a variety of Dowanols such as Dowanol PM, Dowanol PnP and Dowanol DPM.
A certain company was making their own analytical standards. The way the procedure was written required that we order new bottles of solvents each year. I couldn't see dumping year old solvents in the waste drum, so a few made their way back home. Not many - just ones that I thought might be useful. I've also used 99% isopropyl alcohol and butyl alchol (n-butyl and iso-butyl) to slow evaporation of ethanol.
