We value your privacy.
>I need to extract from a Win 95 computer with a 3.5 floppy and a CD reader, but not writer, a file that's 2.3 MB. It has a modem and a printer connection.
How can I get that file so I can transfer it to a Win 98 system?
>If the computer is connected to the Internet, send the file as an attachment to an email address (Hotmail-Yahoo-Gmail-etc) and get it back form the new computer. I hope it is connected?
Another option would be using a USB memory key. You would need the appropriate driver since Win 95 should not know what a USB memory key is. Search the Internet for that driver.
>The email to yourself idea may not be a possibility if your ISP limits the size of file attachments.
I don't know how you feel about poking around inside the case, but if it were me there is a real simple way to do this file transfer.
Since we're talking computers running Win95 and 98, and assuming both are desktop models, I'd unplug the hard drive from the 95 computer and install it in the 98 computer as a slave. There are jumper settings on the drive that must be checked to make sure it's recognized as such. Once properly installed it's a simple matter of booting the computer up and locating the file you need to copy or move to the 98 machine, and doing so.
Otherwise, with a 95 machine, I'd probably use WinZip and floppies.
>You might try a transfer over a serial link, though it will require a null modem type serial cable, but these are easy to make or can be found for only a couple bucks.
>We already have the files on a couple of 3.5 floppies (that's how we've backed up the program over the years), but when we try to put them onto the Windows 98 computer, it overwrites and corrupts the files.
>Assuming a 2.3 meg file, gmail has a 20 meg limit, I believe. If you do not have and account, it is easy to set one up, then just email it to yourself and then download on the other computer.
>Have you tried a file splitter? Do a search and you can find some free ones. Basically, the program takes a big file and splits it into several smaller ones that fit on several floppys. Copy the floppys to your new computer and then the same file splitter program will put them back together into a big file again. I used HJSplit a long time ago when I had a similar problem and it worked for me.
>The problem is that once you transfer the file from the Win 95 machine to the Win 98 machine, the Win 98 machine is overwriting and corrupting the file.
Is this correct?
What's the file? Is it a core operating system file? A DLL for an application? A data file?
I'm afraid that there will be numerous questions following this one depending on the answer.
Making an assumption that this file is replacing an existing file, the first generic thing I'd try would be (all this is on the machine to which you're transferring the file).
Make sure that whatever application or service which uses the file, is not running.
If the application or service which uses this file is part of your startup routine, remove it from the startup routine.
Rename the existing file, something simple like adding "Old" to the name. This is a good check because if the file is in use, it won't let you rename it.
Now that the file is renamed, and the application or service tht uses the file is not in your startup routine, reboot the machine.
Replace the file and see what happens.
By the way, you can drop the file into a temporary directory so you don't have to mess with the floppies anymore. I have a folder on my main drive for just this purpose (C:\temp).
If you drop the file into a temp directory and it still gets overwritten then I have no idea what could be doing that besides a virus that gets really pissed off whenever it sees that file.
>We finally were able to transfer the file and get the newer system working. We had to cut just a bit of it out and Zip it to get the job done, but it's done. Thanks for all the assistance.
