A55 Smoothing Plane
OT: Windows XP upgrade, best $?
Dominic in Buck's County PA
>Hi Gang,
I just got an Ipod Touch and I'm all excited to try it out. So I jump on my computer and try to charge it up. Nothing happens.
Well, I looked online and found that an Ipod Touch is NOT supported by Windows 2000. You need Windows XP or Vista. Now I'm not really that fond of Vista, but we use XP at work and it seems very stable. So I need to buy a copy of Windows XP Upgrade.
I was wondering if any of you knew of a good place to purchase Windows XP Upgrade. I found the home version for $98 and the "Professional" version for $198 at www.newegg.com.
Before I go and drop some dough on this I was wondering if this is a decent price for this software? And is there enough of a difference between the Home and Professional Version to warrant me purchasing one over the other?
See ya later,
Dominic
Re: OT: Windows XP upgrade, best $?
Re: OT: Windows 7.0 is coming out (or has come out
North of the Border
>And what does that do for me?
Dave Paine
>The prices seem the going rate for single purchases.
XP Home does not support a Domain such as your company Network.
Should not be needed if you have only 1 PC, or if multiple will connect via a "Workgroup" or Peer-to-Peer network.
Security features are less than Pro, but I do not recall the details.
I agree XP is more stable, and more important for your WIN2K applications, it should run them. Vista may not run some of the WIN2K applications, drivers for attached equipment.
Be aware some of your equipment may not have drivers for XP. Many WIN2K drivers work, but only time will tell which do not.
I have an HP 1220 printer. XP had drivers for this by now old model, but HP did not create XP version of the maintenance utility, so I lost the nice application to review ink levels, etc.
Someone else mentioned Windows 7. This may be released to the public by Xmas.
Microsoft is allowing anyone to download the "release candidate" for "free". This version will run until June next year, but by March next year will reboot every 2 hours.
Also for WIN2K, you will need to re-format the hard drive, load Windows 7, and then load your applications, some should work, some likely will not work.
I upgraded from WIN2K to XP Pro. Has been generally stable.
Ed Beck
>You can download Windows 7 for free from http://www.microsoft.com/windows/windows-7/download.aspx. This version will expire June 1, 2010, with the bi-hourly shutdowns begining on March 1, 2010. In both cases, you�ll need to rebuild your test PC to replace the OS and reinstall all your programs and data.
This is the Release Candidate build (RC) and is stable. I've been running an earlier beta build on my laptop and have been very happy with it. I loaded the RC onto a new machine that I just bought for photography work. I'm very happy with it as well.
System requirements are:
  • 1 GHz processor (32- or 64-bit)
  • 1 GB of RAM (32-bit); 2 GB of RAM (64-bit)
  • 16 GB of available disk space (32-bit); 20 GB of avaiable disk space (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
These are comperable to the Vista System Requirements
And are higher than the XP System Requirements which are
  • PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required (single or dual processor system);* Intel Pentium/Celeron family, or AMD K6/Athlon/Duron family, or compatible processor recommended
  • 128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
  • 1.5 gigabytes (GB) of available hard disk space*
  • Super VGA (800 x 600) or higher-resolution video adapter and monitor
  • CD-ROM or DVD drive
  • Keyboard and Microsoft Mouse or compatible pointing device
If you have the system requirements for Win 7 I'd give that a try since it's free now, and pretty stable. If it doesn't work out for you, then you can get a copy of XP.
As with all Operating System upgrades or installations BACK UP YOUR DATA BEFORE YOU DO ANYTHING ELSE.
David Yoho
>I think for your purpose, XP Home will work fine. Make sure it comes with Service Pack 3 but those prices sound pretty standard. I always buy my single copies of XP from NewEgg.
David
Jerry Nicholson
>Even if you get a copy of XP Home that does not have SP3, SP3 is easy to install from Microsoft's download site or Microsoft will send you an SP3 upgrade disk for a few dollars. I use XP Home on several computers and have gotten along with it quite well, although you need a separate copy for each computer because of the activation requirement. Windows 7 Release Candidate seems to work well too, a little slower than XP which in turn is a little slower than Win 2000 Pro. $98 for an XP Home upgrade looks like a good price although you might check Amazon.com. Make sure you are not getting the OEM version. My past experience with Windows OEMs is that you need to start with a clean disk before it will install.
Jerry
Forgot to mention..
Jerry Nicholson
>In case you don't know, if you buy an upgrade disk you don't actually need to still have your previous operating system installed. When you do a fresh install from an upgrade disk it will ask you to insert the old operating system disk. This of course assumes that you have a legitimate disk containing the older system.
Jerry
