23 ga pin nailers
Ron gricher
>Can you install window trim and other kinds of trim 3/4 in thick with a pin nailer if so what are the better brands? thanks
23 ga pin nailers
Ron gricher
Doubtful
>pins are headless and primarily used for small (delicate) trim that which needs a fixing "while the glue dries". I think you're better off with 18ga brads or, if the trim is subject to some hits, etc., 16ga finish nails.
Doubtful X 2
Bricofleur
>Same opinion.
I would never use pin nails for trim works. If you want to avoid nail holes filling, use could use construction adhesive.
Best,
Serge
www.atelierdubricoleur.spaces.live.com
Re: 23 ga pin nailers
Rob Stokes in North Vancouver
>I'm using 1 3/8" 23g ss pins (pins were $66/box!!) to trim out a boat with 3/4" trim (teak) and they're working amazingly well. In fact I've tried to remove one or two mis-fires - no-go, they're stuck. Nail gun is a $100 special..
>I don't own a 23 ga. pin nailer, but I have trimmed hundreds of windows. I think the answer is "maybe". If you are nailing hardwood over hardwood paneling, I think the answer is yes, probably. If you are nailing softwood over drywall, probably no. Even then, if you were to glue the back of it to the frame and drywall, probably yes. And I would use a few dots of construction adhesive. My experience is that the jamb will not be flush with the wall, some are proud on purpose, and that makes for less than a perfect glue joint on the back side. Even then, the pins are probably not long enough to reach the stud through the drywall, so you would be stitching it to the drywall. This is an "only time will tell" situation. Visualize your window treatments and trim laying in the floor before you decide.
And I agree about the cost of the nails, Just tried to by a box of finishing nails for one of my nailers. $49+ for a box of a 1000. The guy said "we don't sell many". I guess not.
Ron gricher
>Thanks you answered my ques.
Bill White
>In a word? NO. Not structural in intent or application.
Bill
