Can acetone be stored in a plastic container?
Terry Alexander
>I damaged the top to the original metal container that my acetone originally came in. I don't have any sealable metal containers, but I have a ton of plastic containers. I have about enough left to store in a empty water bottle.
Is this safe?
Reason I ask is that you can always find paint thinner in metal and plastic containers. But I can't recall ever seeing acetone in a plastic container. Yep....I know they are really really really different products.
As always.........TIA
Terry Alexander in West Texas
Re: Can acetone be stored in a plastic container?
Don't sue me, but . . .
steve mackay
>I've got nail polish remover (accetone, yes ?) and " Qwik-Sol " in plastic containers. Would'nt worry 'till we get into the really technical stuff like MEK or Tetro.
Careful!
>As we all know, there are at least 7 types of plastics used for containers. Acetone, being a fairly power solvent for resins (like epoxy) may or may not be stored in plastic depending on a) type of plastic, b) concentrations/strength of the quantity to be stored.
If we have a chemist in da houz, he/she should speak up now, otherwise you'd best put it in the same as what you got it in.
Dale Lenz
Re: If you don't consider glass taboo...
Dale Lenz
>in the shop, it will work. I keep a glass jar of acetone to soak my super-glue tips in all the time. As stated above, plastic might depend of the type.
Re: Don't sue me, but . . .
Howard Norman
>As Mark M said Acetone could be a problem in some plastics. I wouldn't want to do it for more than a few cc's myself. Metal or glass would be the preferred container. Acetone is shipped in gal glass containers all of the time for industrial use.
Bill Howatt
>You can always put the glass container inside a suitable, empty tin can to give it some protection if glass alone makes you nervous. Don't know about now but years ago lab grade acetone was always supplied in glass bottles.
Bill
Yes, but it is better in some than in others.
>Acetone can be stored in polypropylene (# 5 in the recycle symbol) quite nicely. If you only have a thick HDPE (# 2 in the recycle symbol) it can be stored in that - but it is not preferred. Don't use PET (#1 in the recycle symbol) if you can help it.
My preferences are for dark containers (metal or brown glass). Less chance of extracting materials from the plastic. I would prefer dark plastic over translucent plastic.
My $0.02.
Re: Sure! Just ask the wife for her...
Al Stokka - Cambridge, Iowa
>...empty fingrernail polish remover (acetone + stinkum + oils) and put yur acetone in that.
Al
Jesper, Denmark
Re: Sure it can.......
Jesper, Denmark
>Acetone and other solvents and thinners are routinely supplied in dark green plastic containers here in Europe. The containers are marked HD-PE, which I take to mean high density polyethylene.
The plastic is not as impermeable as glass or metal containers, so some seem to shrink a little after long time storage. I have not seen it on the acetone container, but that is maybe because it has been used a lot lately.
My linseed oil and terpentine containers do have distinct dimples in them from losses through the container wall. It is slow enough that there is no detectable smell - and I work a lot with solvents professionally, so I would definately notice.
Acetone Melts #6 Polystyrene on Contact
Tom MacGregoor
Lamont B Dumont
>Very true - chemically, you want an HDPE (high density polyethylene) container. I think that is a "2" recycling code. They are translucent, not clear.
It will dissolve styrene on contact. I used to amuse myself turning styrofoam peanuts into flat pieces of clear plastic on the lab bench.
Re: HDPE (recycle #2)
Henry (Raleigh NC)
>I just looked at the gallon jug of acetone in the lab - at least one commercial supplier delivers acetone in a HDPE (high density polyethylene) jug (recycle symbol #2). That material will likely suffice for the rest of us too.
This is not of course a thin walled collapsible vessel - but a handled 'bottle' that could likely hold up my considerable weight if I were dumb enough to try that (I'm not, at least not today).
Henry
Justin Szeliga
>I just remembered that I keep a bunch of solvents, including lacquer thinner, in Ecover dish soap bottles. No problems for 3-4 years,just the name of the solvent, written in Sharpie, will wash off of I get messy.
Thanks
Justin
Jim Dillon
>Terry,
As others have suggested, either polypropylene (PP) or high-density polyethylene (HDPE) would likely work, as would polymethylpentene (TPX) - all with appropriate caps. Personally, I have never seen acetone sold in plastic containers, at least in the US. While acetone is already in a high oxidation state, it is sold in dark brown glass containers (at least in the US) to minimize chemical change. I guess I would just go out and buy another metal container of acetone at the local Borg rather than spend the money and time shopping for an appropriate plastic container.
Here are a couple of links to plastic/solvent interaction.
http://www.simport.com/en/charts.php
http://www.biocompare.com/Articles/TechnicalArticle/1609/Chemical-And-Thermal-Resistance-Of-Polypropylene,-Polystyrene,-LDPE,-HDPE,-EVA-And-UV-Star-from-Greiner-Bio-One.html
http://www.coleparmer.com/techinfo/chemcompresults.as
Usual caveats for this type of thing. All depends on plastic thickness, temperature, and fatigue conditions.
Jim
