Veritas - Innovation in Tools
A finishing question, one of order...
Glenn Madsen near San Francisco
>I'm building a large library cabinet of tan oak, a California native hardwood under some great stress, due to Sudden Oak Death. The stock available to me has a good number of 'character' spots, small knots and some drying stress cracks that should be filled at some point in the finishing process.
The selected finish is alcohol dye, followed by Waterlox Original Gloss. I've done the end caps, and like the way they've turned out so far. The 24 glazed doors and face frames are next in line.
Somewhere in there, I need to fill the knot holes, likely with epoxy.
Question #1:
Process A: Epoxy, dye, Waterlox
Process B: Dye, Waterlox, epoxy, Waterlox
Process C: Dye, epoxy, Waterlox
Process D: Something else?
All finishing is being done with wiped on materials, because I have not the room to spray anything this size, and would have to borrow a rig to do it anyway...
Suggestions are welcomed, although, old crotchety rascal that I am, I may ignore them. ;-) Don't take it personally, though.
Thanks in advance. There are not many places to ask such questions, and trust the answers. This is one of them.
Re: A finishing question, one of order...
Process A
>I'd get the filling out of the way first. Don't goop up the adhesion by varnishing first. Tint or otherwise color the epoxy before you install it, because the dye won't do anything to the epoxy. Then, sand it all back to bare wood, dye away and finish up.
Re: Process A
>So, if I left the epoxy uncolored, it should dry clear, and look fairly black? I have the Loctite mix they sell at the Orange Borg. I also have some Xerox toner, which, if needed, could be added. If it's not needed, I'd rather pass.
There's no intent to make this look like anything other than a dark filled space. A little character is expected with this material.
I guess a little testing this evening is in order...
BTW, I'm headed over to cut the acacia into bowl blanks in the morning, and to UPS on Friday...
Epoxy regime
>We always used West System here in the shop. If it wanted to be black-black, we ground up some charcoal and added it to the final mix. Use duct tape on the bottom side if the voids are all the way through. I also used use sander dust of whatever species. I'd put a piece of newspaper with a hole in it on the table of my drum sander and sand whatever species I wanted the dust from. I did learn that for a good color match, you might have to go with a lighter species. When it mixes with the epoxy, it darkens. I don't think that would be a problem with a black wood like ebony.
I have not used (or seen) the Loctite product you mentioned. If you experiment with it, let us know how it works.
Use wax paper blocking
>After you (over)fill the void, put a piece of wax paper over the repair and clamp it down with a waxed block. This compresses and flattens the repair.
