OT - Rigid Shop Vac
OT - Rigid Shop Vac
OT - Rigid Shop Vac
Tom MacGregor
>A replacement filter for my Rigid shop vac included the following �Important Safety Notice�:
"If you notice excessive abnormal operation (such as popping, snapping or grinding sounds; smoke, sparks or flames coming from the Vac), immediately stop using the Vac and make sure it is not used again."
Does anyone know how to tell when the smoke, sparks or flames coming from the Vac have reached an �excessive� level? I need an answer ASAP.
Re: OT - Rigid Shop Vac
Re: Hmmmmm
Al Stokka - Cambridge, Iowa
>Tom,
Sounds like you have a real problem there. Excessive somoke, flames, sparks, popping, grinding, snapping seems to me to be subjective.
Since you asked, though, I would say, in my best judgement, that smoke would be excessive when I have trouble seeing or breathing without coughing. Sparks and/or flames would be excessive if something that I like, such as my garage, catches fire. Popping, snapping, or grinding? Don't think I'd worry about those.
On the other hand, I may be paranoid.
Al
Alexander Grigoriev
>It doesn't say excessive smoke. It says that smoke IS an excessive abnormal operation.
I Agree
Gary Evans Tallassee, TN
>My experience has been that once you let the magic smoke out, it no longer makes snapping, popping or grinding noises. Not much in the way of vacuuming noises either. 8^]
I know this post was in fun, but I have to give kudos to Ridgid for the little shop vac that I have. I hook it up to my Ryobi tablesaw and it will pull sawdust until it is completely full. I mean COMPLETELY. So full that you have to shake it to get the top and filter out of the canister. I'm amazed that it is so powerful for no more than it cost.
Gary
Alex Grigoriev
>I bought a little 5gal bucket cyclone for my Ridgid vac (Clear Vue, similar to what Oneyda now has, but better) and it makes WONDERS. The filter stays pretty much clean, and it's much easier to empty the bucket into a plastic bag, than to empty the vac. Though the cyclon doesn't help against fine drywall compound dust.
Another tip: buy another hose, connect it to the exaust port of the vac and lead it outside your shop. This way, the finest and baddest dust won't be in the air.
ROFL ! ! !
steve mackay
Re: RIP...Pop.
Brian in Brighton
>It says to keep it from being used again. This is usually accomplished in the manufacturing world with a Lock Out/Tag Out procedure. Did this vacuum come with such a device and the proper paperwork and training on using it? If not, I would seriously (or not) consider a lawsuit.
On the other hand, I would consider excessive snap and crackling normal, but where is Pop? Did he get sucked into the vacuum? Perhaps the impeller got him. Did he die from smoke inhalation? Perhaps he died from 3rd degree electrical burns? Do we need a funeral for our little morning friend? I'm going to really miss him. My morning bowl will never be the same with only a snap and a crackle. :-(
Are we expected to wear a black armbend in rememberance?
I'm putting my flag at half mast for the rest of the week.
Brian in Brighton
IIRC
>This whole thing arose because of a Darwin contestant leaving the damn thing running for something like 18 hours with the hose mostly blocked. Since Rigid couldn't revise the manuals of machines already sold (but not registered, etc.) the filter replacement notice was their best shot at trying to circumvent the old proverb, God protects drunks and babies, but not idiots.
