Guitar finish?
Guitar finish?
Guitar finish?
Scott in Douglassville, PA
>Hi, all -
'Cause I need another distraction like I need a hole in the head, I'm considering working on a guitar I picked up 20 some odd years ago. It's a big, old, no-name hollow-bodied electric, mainly with stamped steel parts. Fed back like a banshee when last it saw juice, but I plugged the single coils in tonight, and they still make noise. I recently got back into piddling on the gitfiddle after a prolonged hiatus (ahem), and want to get the hollow body back together.
To the point: The guitar was painted cherry red when I bought it from a pawn shop. Hated the color. In a fit of teen ambition, I stripped it and sanded it down to bare wood. There it's sat ever since. Of course, now I can appreciate that the entire thing is nicely curly, almost fiddleback, maple. I'm thinking some chery dye stain is figuring into the mix here. But how? And then what?
I'm not set up for spraying lacquer, unless it's out of a can. Is there a way for me to finish this thing effectively and aesthetically? Any help'd be appreciated.
Thanks,
Scott
Re: Guitar finish?
Re: Guitar finish? *LINK*
Dave Tenney
>Check this out.
http://reranch.com/
Re: Guitar finish?
Re: Guitar finish?
paul woolson
>There's no "required" finish for guitars. Lots of the old purists think that nitro (nitrocellulose lacquer) is the only thing that will make a guitar sound good. Hog wash! The only requirement to keep a guitar sounding good is to keep the finish VERY thin.
I use a catalyzed polyurethane on my guitars. It dries very hard and is easily repairable. But it has to be sprayed to that is a "NO" for you.
Lots of people are using varnish. I know another builder that is using Behlens rock hard right out of the can. Padding it on and sanding it level.(that's the kicker, getting it level). Once it's level, stop. Less is always more on guitars. Finish in general is bad for the sound of a guitar. But it has to be there so make it as thin as possible.
As to the color: If I were you, I'd put a seal coat on the guitar and then tint the finish. Then if it turns out bad, you can wipe it off before it dries. If you do that on bare wood, you're sanding it off.
Re: Guitar finish?
Re: Guitar finish?
>Thanks for the link, Dave!
Re: Guitar finish?
Re: Guitar finish?
>Thanks for the pointers, Paul. I'll check out the Behlen's.
FWIW, here's a pic of the unidentified guitar. Tyring to get an ID on it on some other forums. Some old Japanese model - no name on it anywhere...
Scott
Re: Guitar finish?
Re: Guitar finish?
>Ok, here's the look I was thinking of. However, my son suggested blue. Lee Valley sells blue aniline dye. Hmm...
Re: Guitar finish?
Rehab progress...
>Posting here, to keep it all together...
FWIW, the hardware I ordered for this project arrived Saturday. Of course, it was installed shortly thereafter. Strung it up and have been messing with action and intonation ever since. Have some more fettling to do, then start prepping for finish (which is going to be a blue aniline dye to bring out the figure in the maple, then a bunch of lacquer).
Here's the beast, in current shape. Anyone have any idea on maker? Close as I can figure, it's a Japanese import from the '60s, but not any of the common ones (Teisco et al)...
More to come...
Scott
Re: Guitar finish?
You might get me inspired
Michael Bush
>I've got a solid body electric no name I picked up somewhere about thirty years ago, with the same thought as you. I did pretty much the same work: took it apart and stripped off the baby blue paint. I think it's still at my parents' house thirty years later, in pieces.
You've got me thinking about it again!
But then maybe I'll scratch that itch by making a body and buying a neck. That's another possibility.
Re: Guitar finish?
Re: You might get me inspired
>I know what you mean. I'm wanting to build a guitar now, too. But why buy the neck? Some rasping and shaping, sounds like fun... ;-)
The most amazing part of this whole thing is that I found all the pieces I needed after 24 years in storage. Not sure how that happened...
Re: Guitar finish?
Michael Bush
>Two things worry me about trying to make a neck: placing frets accurately and installing the truss rod. It seems like very small mistakes could screw up the whole thing.
Re: Guitar finish?
Re: You might get me inspired *LINK*
Dan Donaldson
>The fret spacing is really not that difficult. I used a metric scale on the instruments I built because it is easier to measure decimal parts with that system. Calculating the position is also easy. You just need the scale length (from the nut to the bridge). If you decide to do one, I can provide an excel spreadsheet where you input the scale length and it will give you all of the fret positions. (I don't have it written as we speak, but have done it before and it is fairly simple.) The main thing for layout of frets is to always measure from the same point (I use the nut) for each one so that you do not get cumulative errors. The truss rod is also not really difficult. There are instructions on the web and with many rods when purchased. The neck on the bass in shop shots was made from scratch.
Bass
Re: Guitar finish?
Started to finish today...
>Well, spent a lot of time finishing the neck today - sanded through 600 grit, applied a slurry of CrystaLac pore filler, sanded through 600 grit, sprayed some lacquer, sanded with 400 grit, sprayed more lacquer. Lather rinse repeat. Got a dozen coats of lacquer on the neck today. Will rub it out in a few days.
The body is going to get dyed "Vibrant Blue" with aniline dye. The front of the headstock will be dyed the same. But there's no logo or name there. I'm not signing it, since I'm not the builder. But my son has two ideas, and since this will (ideally) ultimately be his gitfiddle, I'm considering them.
Mr. Game and Watch:
Or a Zelda Triforce:
Either way, I think I can excavate the design with a Dremel and chisels, then inlay it with some Inlace. Anyone have an opinion?
And yet another project spirals out of control...
Re: Guitar finish?
More progress...
>Not sure if this belongs here or not, but it's kinda woodworking, so...
I got to Woodcraft yesterday and bought some TransTint, sealer, and lacquer. Got busy with it today. The back before staining:
And the back after three coats of dye:
And the front, with the third coat drying:
I love the color. There's a fair amount of figure in the wood, and the dye brought it out nicely. Have one more coat to do on the side, then tomorrow will start in on sealer coats. Will be applying lacquer Monday...
Woot!
Scott
Re: Guitar finish?
Re: Started to finish today...
Don Evans
>Very nice! I'm sure you are familiar with Stewart MacDonald?
You mention routing out for an inlay with a Dremel, do you happen to have the router base they sell? If so, does it work as well as they state, can you compare it with the base that Dremel sells?
Don
Re: Guitar finish?
That Color is to Dye For.
Re: Guitar finish?
Go straight to lacquer
>It self seals.
Clint
Re: Guitar finish?
Using a "sealer" in this application...
>is like putting butter over margarine on your toast.
Clint
Re: Guitar finish?
Is this your "blue" period??
>That's an interesting shade. I look forward to seeing it with a finish on it.
Re: Guitar finish?
Extra cholesterol...
>...is being called for. This is my first refinish, and the lacquer I'm using specifically calls for a vinyl seal coat. May just be marketing and/or overkill, but I'm following the rec's on it. If I didn't have as much time and effort invested in it, I'd be more open to experimenting. Next project... ;-)
Re: Guitar finish?
Re: Extra cholesterol...
>Vinyl sealers are usual in production situations to achieve an inexpensive sandable film build under a top coat. They often specify a maximum time window for applying the top coat. In my experience, a vinyl (or any other undercoat) is unnecessary. It only adds another step that if not followed up properly, could lead to adhesion problems with the top coat.
Clint
Re: Guitar finish?
>I appreciate your input, Clint. The can says the seal coat is "critical" in use before the lacquer. So, I used it. Third coat is drying (almost dry now). Will let it dry the rest of today, but it's going to require minimal flattening before the topcoating starts.
The blue tone shifted a bit when I applied the sealer, same as it did when I would wet the wood with the the stain. Nice, rockabilly look to it...
Re: Guitar finish?
Just curious.....
>What brand of produsts and kind of lacquer are you using? NC and acrylic lacquers were used straight from the can long before the vinyl concoctions were a gleam in the paint marketers' eyes.
Clint
Re: Guitar finish?
Fred Davis
>Your right in following the manufactuers instructions Scott.
Sanding sealers give you a finish superior in looks, feel and in the case of Vinyl ,more resistance to moisture transfer.
In addition the CAB lacquers I now use , specifically require Vinyl sealer and do not guarantee acceptable results if that step is omitted.
if you reflect on it , you will realize the coatings manufacturers have R@D departments staffed with Chemists who have coatings as a specialty .
Home made brews of finishes are dubious at best , do like your doing and follow the directions and your good to go.
FredD
