A55 Smoothing Plane
OT battery corrosion
peter kolb
>Hi. I have a digital voice recorder and I left the batteries in the device too long and the batteries leaked. There is corrosion on the spring terminals and clips. How do I clean this up? Thanks for your help. Peter in south central NJ
Re: OT battery corrosion
steve mackay
>I'd start with pencil eraser. If it takes more than small steel wool its probably not worth it.
Bill Tindall, E.TN
>water will dissolve these corrosion salts. Maybe a damp cloth to wipe off the bulk of salts and then steel wood, eraser, very fine sand paper to finish off.
GalenV in Iowa
>I've tried to neutralize with baking soda and even tried to tin the spring to make better contact but it took too much temper out of the spring. An ink eraser is more abrasive then a lead pencil eraser to try and clean up the contact.
Depending on how much the unit cost you it may be better to go get a new one if you really need to use one and be reliable.
Galen
del schisler
>vinagar will take the green corosion off of battery term. Use a Q tip That is what they use in the photo lab's Where i worked Retired now
