NEC allows the conduit to be the ground....
Tim Greif - West of Chicago
>Article 250.118 of the National Electric Code allows metallic conduit (rigid, IMC or EMT) to be used as the equipment grounding conductor. So all you have to do is make sure all the fixtures are securley connected to the consuit system and all connectors to boxes and fittings are securely fastened. You are effectively grounded and bonded.
Some folks still feel a separate grounding conductor is good practice. I can't criticize ultra safe practices since as Kneale said, a loose conduit connection can cause a loss of ground. However, I can make the same satement about a loose grounding conductor connection, so you make the call. All that is required by code is to have everything grounded and bonded, by whatever means is allowable in your area. You do not need to run separate ground wires to every switch.
I can tell you from experience that it is important to have every fluorescent light fixture properly grounded, again by whatever means you choose. and it has nothing to do with safety. Without a good ground, the light fixtures will not perform well, especiall in humid conditions. DAMHIKT.
