A Little OT But Not Much - Driveway Problem
Tom Rex in TX
>I have my shop in my garage. I have a large driveway area that I pull my power tools onto when I'm working.
My problem is between the driveway concrete the garage concrete there is an expansion joint that makes rolling the machines over it a challenge.
Is there something that I can put over that expansion joint to make it so there isn't a groove?
TIA,
Tom
Re: A Little OT But Not Much - Driveway Problem
steve mackay
>I managed to cram a length of 1/2 " Plymouth Goldline rope in mine. Won't last forever but since they invented kernmantle I don't use the Goldline (120 ')any more so its got a use now. I suppose you could shove some redwood shim in there but the rope was handy.
Glenn Madsen near San Francisco
>Mine fills with sawdust, unless I actively clean it out with the broom and shopvac.
My tools roll out there for space in the shop, as much as for use. When it rains, I get to work on small stuff. Like today.
Fred Davis
>Tom,
If you run across a hot roofing job in your neighborhood, ask them to come over with some hot tar and pour it in the expansion joint, then you problem will be over and the concrete can still move up an down.
If they don't have a sprinkling can with them, get one and screw off the sprinkle head, then you have a great applicator for the hot
Tar
FredD
Ductwork tin
Kneale Brownson Thru skiing in CO till fall
>Ductwork tin usually is available from HVAC shops where they take out and replace old systems. I've gotten some pretty large pieces of galvanized stuff that has slight creases to make it hold flatness by visiting their scrap bins. They might want a couple bucks for it now. They used to give it away. That would make rolling tools in and out easier.
GalenV in Iowa
>You did not mention the size of the gap and if there is a differnce in elevation. usually got both going on.
You can get a new piece of asphaltic expansion board and a gallon of cold pour and fill the gap. It will still be soft for heavy weights on small wheels.
For change in elevation you can buy an aluminum wheelchair threshold or make your own.
If threashold made of wood you can cut any ramp you need and use the gap to key it into place. Heavy loads may crack off a real thin taper.
The tin attached to a wood piece that keys into the slot (gap)would work.
All depends on the gap, change in elevation and wheel sizes you are dealing with.
Galen
Allan A Campbell
>At my last house, I had a similar gap which I filled with a product I found at Home Depot. It was a coil of a round black substance in a cellophane-like covering, which I assume was to keep it from sticking to itself. You put it in the gap and melt it with a propane torch. It hardens to a non-sticky black filler which is rather hard. My guess is that it is a tar based substance. In any event it worked well. I don't recall the name, but it was in the driveway sealer and crack filler area of the store.
Good luck'
Allan
Andy Lincoln,in Dearborn MI
>A small piece of aluminum "tee" extrusion would work,transition strip from a carpet supply house could work well.
Andy
