Porter Cable 557 Plate Joiner problems-Help.
Ray Carson, New Jersey
>Hello,
I own a Porter Cable 557, type 2, plate joiner and it gets used quite frequently. Recently I've been having some issues with getting the blade cover screws out to change blades. Also, the allen screw that holds the retainer and blade on has been a real knuckle buster.
Well, the other night I went to change the blade from the 4 inch to the 2 inch and one of the cover screws stripped out. After tapping it and using a screw extractor it came free. About 20 minutes on that process.
Then I tried to get the allen screw out to change the blade. Scraped up three of my knuckles and completely rounded out the allen wrench hole. Needless to say that a few explicitives followed as did the wife down the basement steps.
Anyway, now I have to replace the plate cover screw and try and figure how to get the allen screw out without ruining the joiner.
My feeling is that the plate cover screws are steel and the housing is Magnesium or something and they aren't playing nice together. The allen screw appears to be tightening itself, kind of the way a table saw blade does. You all know how the spinning of the blade in conjunction with the threads helps to keep the nut tight....
Question:
Has anyone else had these problems with this power tool?
I'd appreciate your thoughts and suggestions.
Thanks,
Ray
