Kitchen Island top
Kitchen Island top
Kitchen Island top
Ben Ragusa, S Jersey
>I am contemplating a kitchen island top, about 36x72, to be made of 4/4 face grain cherry with bread board ends. The long edges will be glued to double thickness and the "bread boards" will made from 8/4. It probably will have a simple edge profile to hide the glue line. Finish will be some type of oil/wax mixture, no resins. There is no sink involved. The goal is to let it acuire the patina of a well used antique. I'm interested to your thoughts on construction options and finish.
Re: Kitchen Island top
Another edge option
>I made a countertop with 4/4 maple and instead of gluing up the thickness at the edge, I beveled the edges of the counter and glued a 1 1/2" high beveled strip of the same material to it with biscuits. I managed to get the joint really tight and then a pass with a roundover bit made it just about invisible. If you're going to put breadboard ends on your top, just make them out of cherry the same thickness as the height of your drop-edges on the sides.
Good luck.
Ellis Walentine, Host
>I think breadboard ends are superfluous. Wood never sleeps. Use 5/4 or 6/4 without building the edges and run a nice ogee profile around the whole thing. It only costs a little more to go first class.
Clint
Pat Riley
>I made kitchen cabinets out of cherry a couple of years ago. I went through ten million options, and finally went simple.
The glue ups were 7/8 with a 1" build up along the long grain edge just like you mentioned. On the end grain I basically did the same thing - a 1" build up. There was no sap wood in any of the boards, so the end grain blends very well. You really don't notice the joints. In the end the tons of extra time doing the breadboard end thing just wasn't worth it to me.
