Re: hand scrapers
Fred Davis
>Eliot ,
if you add using several light strokes when rolling the edge to what your already doing , then all you need is a little more practice.
One thing about card scrapers, they are not created equal.
They vary in thickness and hardness of steel , the harder steels hold a burr longer , but are more difficult for a person new to the technique to get the hang of .
So , practice and don't give up and when the scraper is giving you consist shavings , then you got it.
Bill and I both subscribe to not making it any harder then it is , a few light strokes with a small flat bastard file is all it takes and if your reasonably coordinated , don't worry about maintaining a exact ninety degree angle to the flat side , a degree one way or the other is not detectable in the result.
I use a good flat oil stone to remove the burr , it takes only seconds do remove it.
When you finally get it going the way you expected in the first place , try keeping some scrapers with different angles on the burr , analogous to rough and fine cutting.
Happy scraping and don't burn your fingers ;-))
FredD
