Drill Press Purchase Advise
Chicago Bob
>Gathering up those retirement tools and need some help with a drill press purchase. Considering 16 to 17" floor models of Steel City, Jet, & maybe Delta. Currently have a 1990 vintage "high end" bench model Delta that I really don't have much good to say about it, including not holding its setup, castings cracking & excessive vibration even with a link belt.
Want to try to keep costs at $600 or less, which is my budget for this tool.
Would appreciate your advise and experience. Both Jet & Steel City have a $100 off sale going on.
Bob
Re: Drill Press Purchase Advise
Re: Drill Press Purchase Advise *LINK*
Dave Anderson (PacNW)
>This is one fine Drill Press. It uses Flat Drive Belts. It is the quietest Press I have ever used. It has a 4 3/8 quill stroke and. a true woodworking table. The 5 year warranty don't hurt either.
Just 2 cents Worth
Jet Drill Press JDP-17 DX
Chuck in ND
>You want the Steel City 17". 6" quill travel, split head casting. It's a very popular drill press.
Marv....... Northern California Lake Co.
>Hi Dave,
Do you find that due to the smallish base that it's a bit tippy?
I usually bolt a piece of plywood under the base or, god forbid, bolt it to the floor.
Marv
>I haven't found it to be tippy at all, but I then I don't live in the California Shakey zone.. The base is not that much smaller than other Drill Presses. That said, this is one sweet unit.
I bolted mine to 4 x 4 s
>I like have it raised up by the 3+ inches and it is more stable for me. I can also move it easier.
Delighted with Delta
Bill Tindall, E.TN
>I use a drill press for general farm work as well as in building furniture. I bought a cheap floor model from Lowe's. With rebates at the time it was less than $300. It has an exceptionally large table, depth stop is easy to adjust, table height is easy to adjust, the table is easy to clamp stuff too and I like the idea of the sacrificial center insert. It might not do for heavy metal drilling but I don't do any. For a woodworking shop I can't think of anything I would want more.
Listen to your feelings
Bricofleur
>As I already mentionned in a prior message, listen to your feelings. Since all drill presses are quite similar, buy the one your like most, even if it's for the color, the closed ventilated motor, the quill travel distance, the confort of the handles, etc.
In 1972 I bought my first Delta (Rockwell) bench top drill press model and it still doing the job. Then I wanted to add a floor model and I bought a 17" General-Intl on sale. Few months later I sold it to a friend and bought the Delta 16" floor model and I'm still happy with it. I should have bought the Delta first since I particularly liked its stop mechanism (and I hated this General-Intl feature). Finally I bought a Delta radial drill press and again, this is the brand I like and the brand I trust.
Listen to your feelings, or even your dreams. Buy something you like, for any reason that might be.
My friend who bought my General-Intl liked the green color and the fact it was a Canadian brand. Even if I hated that drill press so much, my friend is still very happy with his green loving tool.
Best,
Serge
www.atelierdubricoleur.spaces.live.com
Excuse-moi mon ami..... No, no, noooo. ;-) *LINK*
Hikmet C. Sakman -- Victoria, BC.,CDN
>First of all, the "fundamental" issue: Purchasing a tool (especially powered) has nothing to do with "feelings".
Drill presses are not all the same. Please check the link and look at the features of DP and think what they translate into when you use it.
I don't want to get into long winded discussion here. I am referring to the features of this DP, I am sure there are others which have the same or additional features. That's where the dollars & sense come in as well as other issues like warranty/service etc. (for whom may care in greater level.)
Nevertheless, I've the non-VS model and I am very happy with it. It's well built and tought-out drill press.
Chico...
Steel City Drill Press
A Different Tack
Hank Knight
>Bob,
Consider an "old iron" drill press. The saying: "They don't make 'em like they used to," is true, especially with drill presses. You can find Delta, Rockwell, Walker Turner, Buffalo or other classic drill presses for a lot less than you will pay for a new one; and you'll have a much better machine, even if you have to spend a few bucks and rehab it (easy to do). I bought an old Walker Turner, reconditioned it and I wouldn't sell it for 2x what I spent on it. Search Craigslist in your area and you'll probably find several. Parts are available for most of the old classics.
My $.02.
Hank
Re: A Different Tack
Chuck in ND
>I agree about the old stuff, if you can find it. I've had my eye out for an old Delta for along time and haven't stumbled on to anything yet that was local.
Glenn Madsen near San Francisco
>I was waiting for someone to come up with this answer, reading this thread. Makes a bunch of sense.
Not what I did, but then, I was not so wise in the ways of woodworkers at the time, and Woodcraft had a sale on this cool Delta, dirt cheap, as I recall. I'm pretty happy with it, but then, I seldom abuse the drill press, except when I miss having a spindle sander.
There are some cool old machines available, if you're not in a screaming hurry.
BTW, there are sales, such as those you mentioned, fairly frequently.
disagree on this one....
Bill Tindall, E.TN
>Old iron, meaning large to huge industrial machines often available at a tiny fraction of their new price, make sense when one can use their added capacity. Most everyone would find a 20' band saw more capable/useful than a 14', for example. But a drill press used to bore holes, occasionally, in wood? I just don't see big iron providing any useful benefit to the furniture maker drilling holes in wood from time to time.
I just restored a 20" band saw so it is from some experience that I can say that big iron is not without its disadvantages. In the case of the band saw the added capability outweighed these disadvantages. But I don't see it for a drill press unless one's drill pressing needs are most unusual for a woodworker.
Re: disagree on this one....
Hank Knight
>Bill,
I stand by my suggestion. I don't think it's the added capacity that makes old drill presses attractive; it's their no-nonsense, solid construction. When I was a kid, my father had a Walker Turner drill press. It ran smooth as silk. The depth stop was foolproof and it was solid as a piece of granite. When I started buying machinery for my own shop, I bought a nice modern 16" Delta. I was never happy with that machine. It drilled holes just fine, but it seemed a little "flimsy" and the depth stop was a PITA. I ruined more than one piece because it would hold an adjustment. A couple of years ago, I had an opportunity to buy a gov't surplus Walker Turner press similar to my dad's. I bought it, spent some money getting it back in to shape and gave my Delta away. I couldn't be happier. My Walker Turner is a bench top machine, so it's capacity is probably less than my Delta, but it's ten times the machine in terms of smooth, solid operation and easy adjustment. I've posted this pic before, but here it is again as kind of a "re-gloat":
Photobucket
Hank
Re: Hank, thats VERY nice.
Chuck in ND
Fred Davis
>I would take a Walker-Turner anything in a hot second if I had the chance and needed it.
FredD
I had one just like it
>...that was passed down from my grandfather. It was truly a fine machine, straightforward and effective. I still have an old Buffalo benchtop model that is similar, and it is always my first choice unless I need the height capacity or quill travel capacity of my big floor-model Powermatic.
Drill presses are like women....
>Seems you have to try several different models out before finding one that wants to stay in your shop.
Ya got yer big ones and ya got yer little ones, tall ones, short ones. Some that vibrate that you have to chase around the shop. Then there's the ones that just set there and hum away and are just nice to look at whether you are using them or not.
Those big old heavy ones can be very dependable even though you have to overhaul some of them.
I have an old Craftsman that vibrated so badly, it litterly moved across the floor. It's one that has the little thin 3/16" wide belt with pulleys with a dozen grooves. I discovered that the pulleys were not machined concentric to the center hole for the shaft. So I jigged them up in my metal lathe and remachined the grooves and bored and sleeved the one for the motor. Now it's the smoothest running DT I've ever owned. I bought it in 1980. Later I bought a Rockwell as a second DT, thinking I was buying one of the best on the market. Absolute worst pile of junk I've ever used to drill holes with. I hated it so much I gave it to someone I didn't like.
Marv
THANKS FOR ALL THE ADVISE still not sure which one
Chicago Bob
