OT - Zero Turn mowers
Joe Pack
>I have a buddy looking for a zero turn mower to use on his 17 acres. Obviously, a Home Owner special from Lowe's won't cut it (sorry, pun not intended!). What recommendations do you folks have? Diesel or gas, either is okay. The area to be mowed has some rolling hills, but nothing too steep. Some areas tend to be soft after heavy rains, so wide tires are a plus. Also, one that can be adjusted up for mowing high grass would be a plus.
Any suggestions or advice would be appreciated.
Re: OT - Zero Turn mowers
Dennis Yoder
>Here in Florida the majority of the lawn services use Dixie Choppers. They come in a variety of sizes and power. They claim to be the fastest mowers. My neighbor has 2 and loves them. They are pricey but go and go. Kubota makes a nice variety also. Dennis Y
Jason Roehl in Lafayette, IN
>For 17 acres, you're really getting into the realm of a small tractor with a finishing mower on it, attached to a 3-pt. hitch. That doesn't do much for the zero-turn wish, but unless your friend wants to spend forever and a day mowing every week, that's pretty much the way to go. Then he could get a smaller rider or zero-turn mower for the tighter areas that the tractor can't get.
Jason
Grant in Iowa
>Joe,
ZTR mowers are the ONLY way to mow large areas. There are several good brands of machines including but not limited to:
Scag/ Turf Tiger
Grasshopper
Dixie Chopper
Toro
John Deere
What I think is very important, however is what is common in your area. I would suggest you pay attention to what machines are on the commercial mowing contractors trailers and then determine what the nearest dealership carries. This is because ALL machines will eventually have problems and need parts. It is much better to drive 2 miles to the dealership than to have to drive 20, especially when half of the grass is cut.
If all you want to do is mow, then a Zero turn machine is the answer. But, if your friend has other needs such as moving materials, using ground engaging equipment, or moving snow, he/ she might consider a compact utility tractor. These machines can do much more than a dedicated mowing machine. If this is a possibility, suggest you look in to Kubota (usually the BX line is the starting point), and John Deere. Machines in this class can mow open areas as fast as a Zero turn machine, but with a bit less maneuverability. To the plus side, these machines can accept loaders, 3 point hitch items such as post hole diggers, box blades, backhoes, snowblowers, etc. They can also drive generators, water pumps, etc. Tractors such as these can also be useful in managing a forested area, streams, etc. since they can lift, dig, and so on.
You might also suggest that he/ she narrow down the choices and then post the options and needs over at the Garden Web forums, where a lot of professional lawn and landscaping people hang around.
Regards,
Grant in Iowa
Lawrence
>Joe, Tell your buddy to take a look at the Bad Boy zero turn mowers. I have one of their small mowers and really like it. For 17 acres your buddy would need one of their larger mowers. They make a 72 inch cut mower with a 4 cylinder motor.
>Joe, where is your buddy? My cousin is in the commercial landscaping business and has several Hustler mowers for sale, Near Raleigh, NC. These machines have either 200 or 400 hrs on them.
Her suggestion is that he wants a large walk behind mower with a sulkey that you stand on behind the mower. Unless the turf is very smooth a sit on type mower will beat your back to death on that much area. Standing on the sulkey lets your knees take up much of the shock.
I agree with the suggestion that he look around locally and see what the pro's use and where they have it serviced.
Let me know if he is interested the the Hustler machines.
Re: OT - Zero Turn mowers *LINK*
Ray
>Go here and study. The best one to get is the one that has the best dealer service in your area. There are several that will do a credible job. If you have steep hills get a walk behind, ZTR's do not have great traction for hills. If the ground is rough get one with a suspension seat, it will glide over the bumps. My choice was Ferris, great smooth ride, but not the best cut quality (we're splitting hairs here). Best of luck.
Ray
Lawnsite
Phil in NJ
>I have a Walker and love it...
-Phil
A bit too far
Joe Pack
>Thanks, Barry, but we are in northcentral Ohio...a bit too far to travel. :-)
Bob Herrman
>Look at the Kubota Diesel ZD331F-72P. In your area you will never wear out the deck and the diesel will last longer and be more ecomomical then a gas engine. Go to www.kubota.com The other choice is a small diesel tractor with either a belly mower or rear 3 pt hitch mower. When it comes down to it, the consideration should be the amount of time he has to mow. Of course you can get sheep:)
What he needs
Dan Donaldson
>Ducking and Running ;-)
You can't go wrong with a SCAG *LINK*
Ken Garlock, Collin County Texas
>I have the 48" Scag Tiger Cub with a 19 hp engine. It is built like the proverbial brick outhouse, coming in at just short of 1100 pounds. I would not hesitate to buy it again.
Much to LOMLs displeasure, it has been known to mow down a 3' pine tree that was hidden in weeds. (I will never hear the end of that!) It also gets a belly full of 5 foot high Johnson grass, it takes several passes to get it handled, mainly due to the mower deck pushing over the grass stems before the blades can do their work.
Other wise it is a joy to run. If you have a smooth lawn, you can mow at up to 8 mph ground speed. Look around at the large lawns around factories or office complexes, if the mower is orange, it is most likely a Scag.
Hump, sever thunderstorms predicted. That doggone global cooling,
Ken
Scag models
I suggested goats, but...
Joe Pack
Thanks to all. I will pass on your thoughts.
Joe Pack------WebKitFormBoundaryOExgw7MeDkNFu+BA
>Joe,
I have two, a Kubota 25hp diesel with a 60" deck and a Toro 18-52. The Kubota is FAR more machine than the other. One thing I really like is the hydraulic lift on the deck. The mower deck is welded up from very heavy steel, not stamped sheet metal like most. Extra wide tires gives better traction. Note that you do not want to use this type of mower if the grass is wet where you have to go down a hill then turn sharply - you will slide and tear up the ground.
I have 27 acres here and use the Kubota several times a weel around the fields, the lawn, and even under trees in the woods. I mow the horse pastures several times a summer. I mowed a couple of acres just this morning.
A tractor with a finishing mower will be far slower than the zero-turn mower and tear up the ground more. However, the tractor is far more versatile and a real necessity if you have acreage. You really need both!
Note that this question gets asked repeatedly. If you check the archives you will find several earlier threads.
