Gooseneck lite
Woodie1
>Does anyone know where I can get a lite (or parts of) like this?
http://www.woodturnerpro.com/products/goose.html
Thanks
Gooseneck lite
Woodie1
Thanks
Gooseneck sources *LINK*
>I buy gooseneck lamps for $10 at places like HomeDepot, Lowes, Target, etc and then take them apart to get the gooseneck part. You can find them in the lamps and lighting section. They are usually made for desks and bedsides. I've bought a couple that are about 30" in length that are handy size and have been thinking about replacing the bulbs with newer LED.
Happy Woodworking!
http://www.happywoodworking.com/BandsawLight.html
Hang on there a second....
>I took a closer look at the pictures on the website link you posted.......
That's looks like a regular old microphone stand. The kind that are mounted to a desk or a podium. I bought one years ago from Radio Shack or something similar. It looks exactly the same. All you have to do is get one of those new LED flashlights that are the size of a microphone and voila....
Happy Woodworking!
Re: Hang on there a second....
Woodie1
>Can't fine them at Radio Shack web site.
Re: Hang on there a second.... *LINK*
Bob Entwisle in NJ
>Here is a link to one source, or google pro audio equipment and look for mic stands
http://www.zzounds.com/item--MUPDS6213
Re: Hang on there a second....even better *LINK*
Bob Entwisle in NJ
>link to 19" goosneck
http://www.zzounds.com/item--MUP6580
Mark Kauder
>http://www.mcmelectronics.com/product/35-2045
Google wins again.
Mark K
Re: Gooseneck lite
Woodie1
>Thanks, Guys. Now to fine a Magnetic Base.
Mag base, Gooseneck lite *LINK*
Gil Jones....GA
>This one may not be so fancy, but it is reasonably priced, and works well.
Gil
http://www.use-enco.com/CGI/INSRIT?PARTPG=INSRAR2&PMAKA=625-0225&PMPXNO=949341
Re: Mag base,? for Gooseneck *LINK*
Bob Entwisle in NJ
>No sure of the diameter of the attachment point.....
http://www.grizzly.com/products/Multi-Purpose-Magnetic-Base/H3328
2 ideas *LINK*
Dan Mitchell
>I just got 2 of these lamps http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=90766 for $9.99 each at HF, work great on the drill press & bandsaw with a CFL bulb.
In the link below though is a version of something similar to what you have in mind, $7.99.
HTH
Dan
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=96766
Re: Gooseneck lite
GalenV in Iowa
>The advantage of living in a collage town is the goose neck lights of all kinds get thrown out when student move out. I check the Salvation Army or Good Will stores. So far I have found a longer replacement light for my Jet 1220 and one to use with my bench grinder. Both times the cost was $3.99 each. Some have a rigid pipe with shorter flex but you can preshape the pipe for an application.
The magnets of salvage hard drives are small but you are not going to move them as they stick like glue. Easy to add to a base.
Just my source and a good one.
Galen
Don Evans
>It's 1/2", for the price it probably doesn't have much holding power. The better one's come with 130 and 175 lb magnetic gripping.
Click on the "blue" page 648 and it will take you to Griz catalog where there is more info.
Don
You can make a better one!
Don Evans
>I think I would go with the 19" gooseneck arm and add copper grounding wire with no insulation on it. Available at the hardware store.
Buy enough to to make 4 21" long pieces, curl both ends a bit over 1" each end and shove them up middle of the gooseneck. This would add more holding power for the flex and would stay where you formed it.
Lots of places sell strong magnets, like CraftUSA or Woodcraft Lee Valley and make your own base. You'll end up with a better one than you can purchase based on what I've seen.
Don
Re: Gooseneck lite
fred in ct
>how about one of these?
http://www.tools-plus.com/delta-25-869.html
you can get them from coastaltool.com for $18.50
i have one for my bandsaw and it's works just fine.
Re: Gooseneck lite *LINK*
fred in ct
gooseneck light
