Shaker Table
Shaker Table
Shaker Table
Ed F.
>I just finished this version of a Norm project. This is my first piece starting with rough sawn wood (ash). I liked the technique of ripping the front apron into three pieces, cutting out the drawer fronts, then gluing the apron back together to keep the grain continuous through the drawers. I also did my first rubbed-out finish; thanks Wood Central guys for your tips. Finish is General Finishes gel stain (LOML's color choice), Minwax tung oil finish, Trewax paste wax. I think regular varnish or shellac would have been a better choice for the rubbing out process but it still came out great (LOML is very happy to have it in her living room).
Thanks for looking.
Ed Freestone
Re: Shaker Table
Re: Shaker Table
Ed F.
>Construction picture 1
Re: Shaker Table
Re: Shaker Table
Ed F.
>Construction picture 2
Re: Shaker Table
Re: Shaker Table
Rob Hix - King George, VA
>Ed,
Great looking table. I love the attention to detail on those drawer fronts. I love Shaker furniture. Simple lines and straightforward to make. Keep up the good work.
Rob Hix
Re: Shaker Table
Re: Shaker Table
>Good Evening Ed,
That is a very well made table. I examined the top closely as possible, and it looks like you had those boards perfectly grain matched and sequenced. The front frame is also wonderful. Good technique.
George
Re: Shaker Table
Re: Shaker Table
Bricofleur
>Nice work Ed,
You pay attention to details, what gives more 'charm' to this great piece of furniture. It's really elegant, as all Shaker furniture.
Congrats.
Best,
Serge
www.atelierdubricoleur.spaces.live.com
Re: Shaker Table
Re: Shaker Table
Jim Shaver - Oakville, Ont
>Lovelyy work Ed,
I think Shaker is so wonderful, you did a great job capturing it's spirit in this table, well done!
Take care,
Jim
Re: Shaker Table
Re: Shaker Table
>Ed,
Great job. Continuing the drawer faces with the apron is a terrific detail and really makes the piece. Well done.
Tom
Re: Shaker Table
Re: Shaker Table
Ed F.
>Thank you all for the kind words. Gotta give my wife credit for sequencing the three boards for the top; she has a great eye.
One question, though. I had a difficult time arranging the legs. Two opposite sides of each leg showed tight, almost quarter-sawn grain, which I liked. LOML thought the contrast would be too great with the grain in the aprons. She thought the flat-sawn sides went better. Unfortunately, the flat-sawn grain was very different on two legs, very pronounced cathedrals, than on the other two. I picked the two with "quieter" grain for the front.
Could I have made a better choice?
Thanks for the encouragement,
Ed Freestone.
Re: Shaker Table
This is the way to go Ed
Bricofleur
>Hi Ed,
When I saw your table I noticed the flat grain pattern of the back legs. I thought the look of the table would have been a step higher if the four legs would have shown end grain or quartersawn grain. Since I thought I would be a little too fussy, I didn't come back with a related comment.
But now, since you ask, here what you can do to show the same end grain pattern on the four legs.
The attached picture show what you are aiming for, end grain showing on all four sizes. To achieve that, you must rip your leg blank to end up with this pattern. First, cut a square hole in a piece of cardboard. This hole should be a little bigger than the finished leg. Then put the cardboard on the end of the leg blank and turn it around until you will end up with the desired end grain showing. With a pencil trace the perimeter of the square on the end of your leg blank. The final step is to head to your tablesaw, tilt the table to the appropriate angle and rip the board according to the layout lines until you end up with the leg your want. For each rip cut you will have to reset the rip fence and/or the tilting angle.
Another method would be gluing a thin slice of end grain on the flat grain faces.
If you need more info, post your question or send me an email.
Best,
Serge
Re: Shaker Table
Re: This is the way to go Ed
>Exactly my thoughts as well...
Jim
Re: Shaker Table
Ed F.------WebKitFormBoundaryRku3iypSUZ+t93xk-----
>Thanks, Serge. That would do the trick. With my legs, even if I had rotated them to show the end grain toward the front, the flat-sawn grain would still show from the side.
Ed Freestone.
Re: Shaker Table
Re: Shaker Table
Frank Mutchler
>A beautiful job, Ed. Here's a cropped picture of the beginnings of a quadralinear post as designed by Leopold Stickley. Four quartersawn white oak boards are mitered and then glued up around a central core. The picture shows the core with 2 sections attached.
Re: Shaker Table
Re: Shaker Table
Eric Murphy
>Frank, I think the legs of his Shaker table are tapered and it would be pretty tough pulling the "quadrilinear" leg concept off I think.
Re: Shaker Table
Re: This is the way to go Ed - suite
Bricofleur
>Ed, once the legs are done, it's too late to think about grain pattern. As you said, spinning the legs will only show the end grain on another side.
You must apply the method I described before ripping the legs to size. In fact, you take a bigger piece of wood, you trace the square with the cardboard pattern at one end, as mentionned, then you thin/rip it down to the desired size respecting the angles drew at the end of the piece.
Best,
Serge
