Crown Molding on 45 Degree Corner
Tom Rex in TX
>I've got to install crown molding on a 45 degree corner.
Does any one know the angles that I should set the compound miter saw or a website I could get this info?
TIA,
Tom in Rainy Dallas
Tom Rex in TX
TIA,
Tom in Rainy Dallas
OOPS! The corner is 135 degrees not 45.
Tom Rex in TX
Re: Crown Molding on 45 Degree Corner *LINK*
Tim in SE Michigan
>Here is link to table of crown molding angles. Explore the site as well as it has some good information.
Crown modling angles
Tom Rex in TX
>In the link it says "These charts are for cutting crown molding on flat with the 52/38 or 45/45 spring angle crown."
What does "on flat" mean?
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>If you are cutting a large crown which is too large to put upside down against the fence, this will give the two compound angles to achieve the same cut that putting it the other way.
If you can make the cut upside down against the fence, you should just use the 22.5� setting on the miter saw. If you have been coping the other joints, I usually just go with the miter on these wide angles. But you didn't state whether you were doing inside or outside miters here.
Sometimes it is a good idea to make a test cut on a couple of scraps to try the corner.
If it is something like a bay window, I like to work my way out from the back, getting the back and two short sides first, then when you get to the outside corner, you can shove the actual part into the corner where it fits, then mark the outside corner, while also putting a mark on the wall and ceiling.
Then when you work the long walls away from there, when you hold those pieces up, it is a simple mater of picking the lines off of the wall and ceiling on both sides to make sure they line up with the blade before making the cut.
