A blade sharpening question......
Bill White
>I've been cutting a BUNCH of MDF trim with a Freud "Diablo" TK 80 tooth blade. When I went back to wood chair rail backer I noticed that the cuts went much more slowly. Gettin' some smoke too. MDF did a number on the ol' Diablo?
Should I have the feller sharpened since it is not a really expensive blade?
Re: A blade sharpening question......
Tom MacGregor
>If resharpening costs the same or less than getting a new one I'd get it sharpened. If you're going to cut manmade materials you can get a triple-chip blade designed for cutting them and preserve your wood blade(s). I keep several different blades for specific tasks.
Fred Davis
>sure did , if you have a ATB blade it will dull quickly in MDF.
If you cut a lot of MDF or Particle board, get a triple chip configuration blade, that's the grind made for that type of material cutting.
FredD
Re: Did you clean it?.....
pecker
>MDF tends to leave a lot of residue just behind the teeth. Simple Green and a tooth brush will remove it, if you don't have any dedicated blade cleanser products.
I would reach out to Scott........
Terry Alexander
>Scott Whiting with Scott's Sharpening Service.
He has been an contributor here for years and has sharpened many of my blades. I "think" he doesn't respond to e-mails like this here so as to abide by the "no solicitation" policy.
Anyway....Scott will answer your e-mails personally. His contact info is: scottsharpaz@qwest.net
No affiliation with Scott....just a recommendation on a good honest vendor.
Terry Alexander in West Texas
Lee Grindinger
Fred and Tom are correct
Lee Grindinger
>ATBs, alternate bevel teeth have points that wear quickly in man made materials like MDF, particle baord and MCP. While a high angle ATB like the HiAT from Forrest is necessary for good cuts in MCP providing a decent cut on both sides, they dull rather quickly.
A TCP (triple chip) is a more durable blade when only one surface needs a clean cut, a TCP will tend to tear out a bit on the underside of the cut but will last a long time for the topside.
It's all about tooth wear and the triple chip will outlast an alternate bevel in these materials.
Lee
Re: Fred and Tom are correct
Bill White
>Thanks guys. Oh yeah, I keep 'em clean ALWAYS.
Hsd the blade sharpened today. $13.00 while I waited. We'll see how it works out.
Bill
