We value your privacy.
>I am working on a carport for a family member. Has about 9" of slope in 12'. We were planing on using roll roofing. Considering using the Huber Eng. Zip system plywood that is coated and taped. Has anyone done something similar that worked well?
Re: OT Anybody done a successful flat roof yourself?
steve mackay
>Had to replace our flat roof a couple years ago. Actually I've got no slope. They used 3/4 ply, felt and a roll rubber membrane that has a granular gravel-like top. Cant remember the trade name but it was developed for trailers and RVs. I know they applyed hot tar then rolled out the membrane then melted and sealed the seams. I've essentialy got a rubber-linned, inverted swimming pool up there. 10 years and its still like new. No dregredation in the rubber. The biggest worry, according to my contractor, is in the application. If its not installed EXCACTLY according to the manufacturer's instructions you void any warrantee from day-one. I went so far as to call Dude to seal up around my new wood stove chimney just to be sure. I think flat roofs get a bad rap. Sure, a peaked roof is always better but a properly installed flat roof has no real worries. By the way (because SOMEONE is going to call me out on this !) we get no snow to speak of so its not a consideration.
Joseph Mulherin, Sr
>Barry, I did my son's carport a few years ago, 12ft x 22ft w/4"slope. Used regular 1/2" plywood, then rolled regular 90lb roofing over it. Sealed edges at roof with caulking and cold roofing cement.... never any leaks.
R. Gryder
>Barry,
If you are concerned about roll roofing, look at what is called half lap roofing. Basically 90# roll roofing 36" wide but laps over 18" I have used it in the past over some low pitch roofs and had good results. R.
>and it's held up, even through my son punching through it for a wood stove chimney and me subsequently patching it after removing the chimney.
Pitch is minimal on a 12 foot by 12 foot roof - can't remember, maybe 3-4" over the whole thing, maybe less.
I understand torch down's gone out of fashion and may be hard to come by. I understand why - it's a fine line between melting the roofing enough to bond and setting the whole thing on fire - but it makes for a substantial roof.
I hate flat roofs in any kind of rain country - water should be able to flow off a roof. But we would have had to redesign the structure's roof entirely, and I wasn't quite ready for that at the time.
>We redud the community pool club house flat roof almost 20 years ago. There have been no problems whatsoever!!! Why, because we used trusses to make it a pitched roof!!!
There are two types of flat roof- ones that leak and ones that are going to leak.
Justin Szeliga
>There is a product called Flintlastic, which comes as a torch down (OH NO MR BILL!!!!!) or as a glue down. It's roll roofing w/rubber added to it, glued down with asphalt w/rubber added to it. Nice, should be fine for a carport w/that low a slope, & doesn't involve an amateur using a flamethrower on top of a wood structure. I love the stuff for low slope work, won't go back to the regular roll roof. The flexibility of the stuff is amazing, I've rolled it into a 2" diameter tube. Try that with regular roll roofing & it cracks at about 6" diameter curve.
Gotta get it a a real roofing supply house.
Peace
JJS
