Porter Cable 390 ROS first impression
David Paine`
>After many years being disappointed dust collection on my 6in BOSCH ROS, I recently decided to buy the Porter Cable 390 ROS which is 5in.
I used to think the "smaller" 5in diameter units were too small. Sometimes smaller can be better.
The P/C 390 has 8 hole discs and comes with a plastic dust collection drum made of a porous plastic. I do have not tested this, since my intent was to use my Fein shop vac when sanding.
The P/C 390 specification talke about 1 and 1.1/2 connection ports. When I bought a Ridgid quater pad sander with 2.1/4 port, my Fein connected as expected.
The P/C 390 ports are the same diameter as my shop vac hose. Perhaps I should have interpreted that the specification meant the exact same size, and not a size to accept e.g., a 1in hose, which is what I expected based on the Rigid unit.
After some experimenting, I found a piece of 1in PVC water pipe fitted over the 1in port and inside my nominal 1in shop va hose.
Once I had my dust collection established I tried out the unit.
The combination of 8 holes, better air blower within the sander, and my shop vac results in zero dust. The unit is quieter than the Bosch, is very easy to operate single handed and does stop faster as claimed in the brochure.
The P/C 390 is a pleasure to use. I think I will be giving away the Bosch, even though I have a good supply of the 6in 5 hole discs in various grits.
I bought this unit and also zirconia sanding discs from Klingspor, clicked in from Wood Central. Terrific combination. The zirconia does not load up with particles. More expensive, but lasts longer.
No affiliation with P/C or Klingspor, just happy customer.
