OT-Concrete form Question
Sawman
>I need to re-do my chimney cap/wash and I am going to increase the thickness abit so I will need a form. In order to allow the cement to "release" from the the form cleanly what is used?
As a woodworker I was thinking shellac or wax.
Re: OT-Concrete form Question
>I used to use motor oil (used) when we did it years ago. We wiped the oil on the wood (several coats).
Re: OT-Concrete form Question *LINK*
GalenV in Iowa
>This should give you some suggestions.
I would think used motor oil would stain the concrete surface.
Guess I got by a lot of times with no treatment but then you may be looking for a smoother finish.
For precast slabs from a single mold I did use epoxy paint to get multiple parts and not have moisture damage the wood form.
Galen
Concrete form release
Hamish
>Try brushing on some diesel. When I have done something like this, I leave the form on the concrete for at least a day. By that time, the wood begins to dry and comes away from the concrete on it's own.
Remember when you pour the concrete to agitate the mix as much as possible, including vibrating the form by tapping it with a hammer to cause the concrete to work it's way into all the corners.
Good luck, Hamish.
Lee Schierer - McKean, PA
>Make sure you put the trowel between the form and the concrete and jiggle it up and down all along the form to remove bubbles and get the sand and cement to move toward the form.
I think that once the concrete sets up so you can float the top, you can also remove the forms and float the sides.
Lee
>I've used diesel and motor oil mixed with mineral spirits to make it easier to brush on. Both work. On a very small piece to close off the end of an edging run beside a walk (still in progress), I even used WD-40, obviously not cost-effective for a full form.
Gary Camp, Bend, oregon
>For a smooth surface use one side good MDO put some Diesel in a garden sprayer,or you might just try paste wax. first job out of High school I was a Building Laborer, the re-usable forms we used on a five story hospital were rough (resawn) plywood with a custom v-groove pattern. We used some fancy spray on wax that smelled kinda like laquer, a one time application.
A quick and dirty vibrator is a recip saw without the blade, put the foot up against the form and pull the trigger.
glc
Fred Davis
>Sawman,
since this is a small form and you don't have form oil handy, line the form with something like Saran wrap, plastic garbage bag etc.
Use a sack of Mortar mix , not concrete mix and the finished cap has a rounded top , rather then a flat , sharp edged one.
You will have the best luck floating the mix to the shape you want with a rubber float , available in all hardware stores.
Make sure the brick is clean and damp before you put the Mortar Mix on it.
Don't raise the cap above the flue liner, if you can help it.
A cement Mason would not need a form for this job.
FredD
Jesper, Denmark
Jesper, Denmark
>A very simple method is to line the form with plastic. � just finished a repair of the foundation wall on my house, where I stapled plastic sheet - Visqueene - the stuff used for vapor barrier - to the form. with proper vibration with the trowel and a slightly wet mix, the resulting surface was perfect and did not need trowelling afterwards. The form separated very easily.
>Fred and basically everybody else have given good advice.
If you feel you need a for, you may be able to strap it on with a strap clamp to avoid nailing into your chimney. You can oil the form with most any oil, including motor oil. Or you can line it with polyethylene or even packing tape. the concrete will take on the texture of the form. If you pour a wet mix and vibrate the form as suggested, if you line the form with poly, you could get concrete as slick as a dinner plate. The form should come off very easily either way, but you may not want that super slick surface.
Think the form through. You want to design it to come off easily. Especially if you are going to strip it in less than a week. For several days (about a month), the concrete will be very tender and easy to break, so if you stick a pry bar between it and the form, it is likely to crumble. So remove the form gently.
Fred is right. Unless the concrete is going to be over two or three inches thick at the edge you don't really need a form. (Think mud pie) You should wet the top of the flue/chimney and plop nice wet concrete onto it and jiggle it tightly onto the surface and then shape it with a trowel.
