Assembled Settee
Assembled Settee
Assembled Settee
>So it is the newest furniture in the house. I did NOT pose Maggie. She thought it looked comfortable, so she got up on it. I did not use fish hide glue, though I did use hide glue.
Leg detail and center stretcher detail.
Arm post and seat edge detail.
Seat detail.
The seat and legs are cherry. The spindles and hoop are white oak. I used maple wedges for the leg tenons and the bottom of the arm post tenons. I used cherry wedges for the spindles and the arm post tops. I used hide glue throughout.
I wondering if I should put a toner on the white oak and give it a bit of cherry color or whether I should just leave it natural. I think it looks good, but I'm prejudiced.
Re: Assembled Settee
~5 hours and no comment? There are pics above.
>I expected at least one on Maggie :).
Sawman
>Very Nice! I can appreciate the work as I did a Windsor Chair course with Mike Dunbar years ago. The amount of work that goes into a piece like this considerable.
GalenV in Iowa
>What can I say the project is well above my woodworking ability!
If I tried it would look like when you dump a whole box of toothpicks on to of a wood block covered with glue.
As for your Maggie she is just waiting till you put the first coat of finish on it and then she will climb back on it. Never had to rub out cat hair!
Looks Great!
Galen
Re: Assembled Settee *LINK*
Mike Hamilton
>Very nice JL. The Maggie pic doesn't show for me in your opening post(assume it's the first and I see a basic red X). How did working a cherry seat compare to poplar or pine?
Pete Galbert has done some non-painted Windsors combining cherry turnings, white oak rivings and butternut for the seat. Somehow he gets a pretty uniform look. You might be able to dig up some of his finish info from his blog. His current entry is about settees (shortening the turning spacing on the center legs). Scrolling down a couple entries shows one of his cherry, butternut, white oak chairs.
Again, nice work.
Mike
Pete Galbert's blog
Maggie pic
>The picture in question.
As far as the differences...
>Cherry is a LOT harder. I can hand carve butternut, eastern white pine or cypress - which is what I always have used for seat material. Cherry weighs much more also. I started with a 2" actual x 20" x 44" piece of cherry.
Re: That's beautiful work, JL
Glenn Madsen near San Francisco
>Did you steam bend that continuous arm? Or procure it from a supplier?
I'm in process on some Windsor high chairs, and looking at my first compound bend. Bowbacks, no problem. For these, I'm making my first double form from the Dunbar book, and hoping for success. We'll see.
I'm a ways from doing your settee, though. Nicely done!
Supplier???
>The supplier was Josh Dyer. He found me a nice clear 8' log section of white oak.
I started with an 8' log section. I rough split it into smaller pieces (which I shared with some friends).
I rough shaved a piece to ~2" x 1 1/2". I then shaped it to ~ 1 1/2" x ~ 1 1/4" x ~90" piece of green white oak. The orientation was such that the growth rings were oriented so that they were roughly "parallel" to the narrow diameter (~ 1 1/4"). I marked the wood for paddles and center line. I then rough shaped the paddles (for thickness) and the rounded center portion. I then marked how I was going to "trim" paddles. The dimensions of the finished hoop were 88" long with two 17 1/2" paddles that were ~5/8" thick and 1 1/4" wide on either end. The middle section was ~1" in diameter. The top of the paddle line is the same growth line as the top of the rounded center portion. The rounded portion starts transitioning into the paddles at 17 1/2" in from the ends.
I steamed it for ~1 hour at 210 or so. I then bent it around the form.
Ellis Walentine, Host
>I don't know about anyone else, but this kind of work inspires me, JL. Having watched you make the settee through your several posts about it, I can only admire your craftsmanship, not to mention the lines and feel of the finished product. Really wonderful work.
Alan Young
Alan Young
>JL,
Thanks for the pictures of the Settee. Lots of skill here. It is as Ellis says inspiring. Did you post pictures of the bending process for the arms/back? Do you split that piece from green wood and then work it?
Looking forward to pictures of the finished piece.
Alan
Re: So you did it the _honest_ way!
Fred Davis
>Well that level of skill does inspire me Ellis , but my inner voice says... don't go there. ;-))
Excellent piece and nicely done.
FredD
>I split the piece from an 8' green white oak log. I didn't take pictures of the bending because I was bending :).
