OT Tires
Sawman
>So my wife's Honda needs new tires. This last set has about 40,000 miles and now need to be replaced. What kind of milage do you guy's get on a set? What kind?
Thanks
OT Tires
Sawman
Thanks
Re: OT Tires
>I have owned Honda's for years. (CRVs and Accords) I am running a set of Michelins on my current CRV and have over 60,000 on them now. The front ones appear to have about 5,000 left in them and the rear ones may have ten or more.
Once, I looked at the charts they have at Costco and noticed that their "other Brand" tires (Armstrong?) had very nearly the same ratings as the Michelins and were about a third cheaper. I bought a set. What the charts did not reveal is that those tires were very noisy compared to the Michelins. Really Noisy. I could not wait to replace them. Back to the Michelins.
Tire Rack surveys *LINK*
Joe Pack
>I have not purchased from this source, but have used their customer survey ratings many times. Tires are rated by actual users according to wet/dry/ice/snow traction, noise, mileage, etc. Not a 'gospel' by any means, but probably a wider survey of opinions than you will find anywhere else. Make sure to look through the entire site...lots of good info here on tire types, function, styles, etc.
Tire Rack Survey Results
Re: OT Tires
GalenV in Iowa
>2005 Nissan Altima 3.5 SE with performance tire as original equipment took them off at 35,000 miles and for the way I drive thought that was good. 40,000 for Honda Accord V6 about the norm for original tires.
Replacement Altima tires have only 4,000 miles and are Goodyear Assurance Tripletred 215/55R17 directional tread. Got good traction in the snow and are mid range for noise. POOR handling on interstate that has ground surface parallel to trafic flow. Car wonders as bad as a touring motorcyle on 6" depth of new gravel! Fine on other surfaces.
2005 Honda CRV has about 39,000 miles and could get 6000 miles on original yet for summer needs, unless it rains a lot.
I found in my search that Michelins can be as cheap as any other as they have a low grade tire too and I had always bought a better grade in the past. They did not have my size in a better grade.
I'd almost rather buy a new car before I go out and buy tires. As it turns out I usually trade just AFTER I get new tires. Not very logical I guess but someone gets a good trade in.
Galen
Re: OT Tires
Nat Robison
>I think that 40k-50k is about right for tires. I currently have about 41k miles on an '05 Mazda and the tires probably have another year left in them. I know there are tires out there that have 80k warranties but I've also heard it advised (probably from a tire company) that tires should really be replaced after 5 years regardless of mileage since the rubber can dry out and crack. Since we only put about 10k on our Mazda per year, I probably wouldn't want tires on there for 8 or 9 years.
p.s.
Nat Robison
>p.s. I had a 98 Honda that came with Firestone tires. Replaced them once they wore out with Yokohamas and they made a big difference in the handling and steering. The car did not have power steering and the Yokohamas made steering much easier.
Re: OT Tires
Chris F.
>Do you live in a snowy area where you'd need all-season tires, or in a warmer climate where summer tires would suffice?
I'm in the snow belt, and have a set of Pirelli P4s on one of my cars. Great tire for the price (and very highly rated at TireRack).
I've used Tire Rack
Dan Mitchell
>I was very pleased with the price & service, though the majority of credit for the "service" part really goes to the local mobile mounting guys who came out to mount & balanced the new rubber.
Re: OT Tires
John McGaw
>There is no way to say definitively how many miles a set of tires is going to last. Example: my Miatas have never gotten as many as 20K and more often 15K was the limit. The reason is that the tires I buy are made for performance and have softer compound. The fact that I see every bend in the road as a challenge probably contributes also. On the other hand my 1981 VW diesel pickup (yes, they really did exist) got 130K on the rear tires -- the original tires were on there after 16 years when I got rid of it before leaving Alaska. This vehicle put just about zero stress on the rear tires and the stiff sidewalls meant that I could have a nail in one of them and no air pressure and I'd never know until I put a load in the bed.
If you don't care about performance on the average family-type Honda, buy yourself one of the guaranteed high-mileage tires and I'd bet you could get 60K if you keep the tire pressure correct and rotate every 5K.
Re: OT Tires
Jim Dillon
>Sawman,
I've done the same thing as Joe and used the info at Tire Rack to help me select my last three sets of tires and have been happy. In fact, I am searching them now for my next set. My local dealer was able to then get the tires and provide a competitive price. Tire Rack also lists dealers who will install their tires, but I don't know how warranties, tire rotations etc. are handled. Tire Rack's search engine will allow you to isolate user comments relative to your specific car model, if available in their data base. My 2 cents.
Jim
Me too.
Tim Greif - West of Chicago
>I have bought from TireRack, and so have a number of friends. Very good pricing and they drop ship to your chosen local tire shop and have a pre-negotiated mounting/balancing fee for that shop stated up front on the web site.
Kelly Navigator
Lee Schierer - McKean, PA
>We replaced our factory installed Michelin tires on our 05 Mazda 6 (same size as Honda Accord) last year with Kelly Navigator tires. WOW what a difference. We got much much better winter traction than the Michelins. The day I had them put on, it was snowing like crazy. We have a light that comes on to indicate when either front wheel slips while driving. All the way to the tire place, the light was coming on almost constanly. On the way home from the tire dealer, despite having far more and steeper hills to climb the light never came on once. Yeah, I know the new tires had better tread, but you have to understand the original michelin tires (all weather types) never gave good traction in the snow. ThHy would also about shake the car apart whenever you crossed one of those open grind bridges.
Re: My philosophy on tires...
Jesper, Denmark
>Granted, the driving conditions here are a bit different from North America - higher highway speeds on narrower roads with more bends than in the USA. Both expressway and ordinary roads.
I buy the best rated summer tires based on a very thorough testing by the German auto Club, ADAC. My main interest in summer is the best performance in the wet.
In winter I follow the same recommendations, mainly focusing on snow and ice rating, but also on just wet roads, as we have most of that here.
I have just replaced the first set of tires after 60,000 miles ( 100,000 km) and need to replace the winter tires in the fall. My guess is that the summer tires (Bridgestone Turanza) had 40,000 miles on them and the winter (Goodyear Ultragrip 7)about 20,000 miles. The new summer tires are Michelin Primacy HP in a W speed rating.
The summer tires are 205/55-R16 for good handling and the winter 195/65-15 as they are the original size, but the narrower tires do better in snow.
Strictly speaking, the winter tires are not strictly necessary, as we do not have much snow here, but as I do drive in other countries - particularly Germany - where snow and ice rated tires are legally required in winter, I do have two sets of wheel with summer and winter tires. The wheels are light alloy, simply because they are turned and completely round - which steel wheels are not.
I do occasionally push it a bit, so as the tires are the only thing transferring forces to the road, only the best will do.
190 km/hr (90 mph) on the Autobahn is not unusual.
Ohh, and with a 140 HP 2.0 liter Diesel, that gets me 40 mpg at speed and 45 mpg on average.
The car is a Skoda Octavia Combi Wagon - in between Golf and Passat size - Audi quality built in Czech Republic.
Cost of a set of four tires mounted, balanced and new valves is about $700.
There you have it - more information than you wanted.
USED ! . . .
steve mackay
>Here in El Paso the streets are so littered with junk, nails and potholes I buy used tires for twenty bucks and run 'em till they fall off ('bout 2 years.)
Oops, that was a rant was'nt it ?
Re: OT Tires
AZ, Colorado Springs
>I had a Nissan pickup truck with Bridgestone tires and they lasted 80K miles. Those were the original tires. I go to Discount Tire and buy whatever they have that's rated for 40K or better, if they're on sale even better. Get a road hazard and they provide lifetime rotating and balancing. (I am retired from the USAF and moved around -- when I lived in Spokane, where there was no Discount Tire franchise, I went to the Firestone Mastercare, but did not worry about "name brand" tires. There's only a couple of tire factories anyway, so whatever you get is made in one of those factories.)
The tires last me at least 40K. It's important to note that you should rotate and rebalance the tires regularly, keep them inflated properly, and keep the front end of your car in algnment, as others have noted. Your car is a transportation "tool", and it deserves the same attention to care and maintenance and your other tools. :0)
Good luck!
Re: OT Tires
Alexander Grigoriev
>ROtate your tires.
