Veritas - Innovation in Tools
Recent Project - Liberty Torch display case
Louie Lovas
Louie Lovas
>Hi all, recently finish this display case for my wife. It hold a very old piece of stain glass (about 100 years old) that measures 25" x 12". It's a Liberty Torch that as one of many that was part of the facade of my wife's grandmother's delicatessen in Jersey City. The building was torn down decades ago, just getting around to making the case.
The display case is actually a lighted box, I mounted 3 fluorescent lights in the interior. Two 18" tubes along the sides and a 3" puck in the center behind the (ruby red) flame. I used fluorescent to keep the heat to a minimum, but still vented the interior.
The stain glass is mounted in a frame that's hinged to the box. I also mounted a piece of frosted glass behind it to diffuse the light.
It's mounted on the wall in our dining room (see last pic, with the lights on, looks alot better that the photograph actually). We had an electrician friend wire it in behind (so no dangling wires below) and add a wall switch for it. Now the wife is happy (at least for a while...)
Just thought I would share ...
Re: Recent Project - Liberty Torch display case
Very nice
Dan Donaldson
>The backlighting really sets off the glass.
REALLY BEAUTIFUL - VERY NICE JPB!
Chicago Bob
Very tasty, Louie
Ellis Walentine, Host
Neat project!
Tony - Memphis
Bricofleur
>This is nice work. Congrats.
I like the bright idea of backing off the glass work with light.
That would be a nice intarsia project too (no light though).
May I add a suggestion: When making the saw kerfs for the corner splines, use a flat bottom tooth blade so you won't get the "ears" from the outer edges of the saw teeth. Or you may file the bottom of the kerfs down.
Best,
Serge
www.atelierdubricoleur.spaces.live.com
Louie Lovas
Louie Lovas
>Thanks for the tip on the splines. I use a crosscut blade (ATB tooth pattern) to cut the splines - which clearly leaves those little ears. Never thought to file them away (quite tedious!). Didn't want to use a flat-top rip blade - figured that would increase the likelihood of chip out in the box corners. I did find a flat top crosscut blade from Infinity Tools ...
http://www.infinitytools.com/products.asp?dept=1484
...but the kerf (5/32) was too big for my liking.
I regularly use splines on mitered corners (frames and boxes). For both visual appeal and added strength. For boxes I saw them at a 12 degree angle (love the look), I have a jig that rides on the table saw (in the miter tracks) that cradles the box as it cuts the splines, works really nicely.
thanks again,
Louie
