OT: Zip Line
Larry Barrett
>Anyone built one for kids or grandkids? Any suggestions on poles, supports? Any cautions or strong suggestions to do something else?
OT: Zip Line
Larry Barrett
Re: OT: Zip Line
GalenV in Iowa
>Just be sure to get good insurance.
Trampoline bad enough with broken fingers and out of joint shoulder and one hanging in the basketball hoop from a dive off it. Then there was the snow ramp that shot them into the top of a large evergreen down a 600 foot hill in the back yard. The water slide down the same hill in the summer. NO ZIP LINE!
Kids are older now and dive off mountains and hang from lines in the top of the Australian rain forest, so they have grown up now. Right!
Galen
Re: OT: Zip Line
jeff
>Larry
Forget poles, you need to have a really strong anchor, like a big tree.
You need to use a "static" rope, not a climbing "dynamic" rope, or any other type (manila, hardware store nylon, poly, etc.)
No hardware store pulley's, get a climbing (or rescue) type pulley.
How high and how long is important.
How do you plan to stop the slide?
Best is to have the rope in an arc, so the person riding the zip line comes to a slow, easy stop.
Hitting the ground (or a tree, pole, etc) can cause alot of injuries if done at speed.
Get some professional help if you aren't sure of what you are doing.
Jeff
Re: OT: Zip Line *LINK*
alister
>I did one
Used wire rope
Boy scouts say a foot drop in 25......this is quite tame as drops go.
Of all the backyard goofy stuff I've done with the kids the zip line is a favourite with visitors.
Zip line
Incredible work, Alister
Ellis Walentine, Host
>I looked at your treehouse site and was blown away. Congratulations on an amazing job and a chronicle nicely told.
Re: OT: Zip Line
Larry Barrett
>Alister - I agree with Ellis, your treehouse and attachments are terrific. You encourage me to build the flying fox/zip line for grandson and playmates, who are about the age of your triplets.
wow- I love the hammmock! great build!
Alan Young
Re: OT: Zip Line -question
Larry Barrett
>Alister
You said a drop of 1' in 25', so I take it that for your 160' run the difference in elevation between start and end was about 6 feet. How much sag is in the line when a (say 40-50 lb) boy is on it (how taut is the line)? It would seem that you need the elevation difference to gain some speed, but also some sag to assist in slowing at the end. When a rider nears the end of the line, does he slow to a stop, or does he need to apply feet to tree to stop?
You designed your line for your triplets (about 5 or 6 years old I would think, judging by the pictures). What concerns would you have if a heavier child climbed on?
alister
>The line does describe a curve.
The way the ground lays the person riding will run into the ground about where the people are standing...not enough momentum has been gained to hurt anyone by that point...If a kid is riding in that seat they are instructed to lift their legs up before hitting so they won't get caught under the seat and have that plastic hit the back of their calf muscles.
Adults can ride it and do....they'll just step off...If they don't they end up dragging there butts on the lawn...which is pretty funny.
The line does drop a bit when the rider gets on...but not that much.
the cable was pulled tight with triple blocks to gain advantage...this bit took some effort.
the kids were around 5 or 6 ....but they keep growing and are now 10.
I did install a line for a friends kid and the 1 in 25 drop was just to tame for him., so we made it faster ...but I couldn't tell you what ratio that was.
On that line it terminated between two trees and the zip line describe a "Y" and the rider would swing to a stop.
I have seen tires threaded onto the line to act as a brake but have not tried this myself.
I dealt with a stage rigging company for the fittings called "FEHR Brothers"
Aluminum plate and skateboard wheels
>I've made a few.
Best one I've made is using 100' of 3/8" steel cable, between two really big trees. Use of chain around the tree as well as 2x4 scraps on the tree to protect the tree.
The zippy thing is fun to make. I take two pieces of 1/4" aluminum, about 6" x 12" in size. I sandwich two or three skateboard wheels between them along one of the logn edges, then put a long 3/4" bolt or a pipe through it with some foam bicycle/motorcycle handlebar grips on it.
I use my lathe to cut grooves in the wheels before installing them. Then I put a half-slice of 6" PVC pipe on the top to keep the rain out of the top.
I'll find or take some photos in the next day or so if you like.
Happy Woodworking!
Re: Aluminum plate and skateboard wheels
Larry Barrett
>Mark - A pic would be nice if you have time. I think I got it, though. The 2 or 3 skateboard wheels sandwiched between the plates ride on the line; line can't jump off because of the plates. The bolt or pipe goes through the aluminum plates below the line and serves as handles to hang on; and I suppose a seat can be suspended below this. I checked out Alister's CMT rescue pulley; new ones are in the $80 range. I did not check ebay yet.
No trunk wraps
Tom Dunlap
>The loads that are generated on a zipline are HUGE! There can be a large multiplier because of the changing angles so a person weighing 200# could generate a load of 1.000# easily in the right [wrong?] conditions.
Calculate at least a 5:1 and better yet, 10:1 safety factor.
Wrapping the cable or chain around the trunk isn't a good idea unless the zipline is temporary. I've seen too many cables/chains/wires girdling trees and doing damage or killing them.
If a j-lag is used be sure that you use a large one since the mild steel j-lags around now aren't really that strong. It would be better to drill all of the way through and use a forged eye bolt or threaded rod and an Amon eye nut.
Make sure that fingers can't get anywhere near the pulleys on the cable/rope. It is natural to reach up to grab the cable or pulley which could easily cause a severe injury.
Ziplines are a load of fun...but they can be dangerous too.
Making Smiles
Jennifer@Indy.USA
>Alister I totally enjoyed your Treehouse site. What a wonderful place to hang out with your kids! I can't think of a more wonderful thing to have built for them. You're making smiles and memories for sure!
Jennifer
