Master of none
Ellis Walentine, Host
>When I was doing research for an article I wrote in 1992, in American Woodworker about combination machines, I was amazed to find that more than 424,000 Shopsmiths had been sold since the first model was introduced in 1947. Presumably, there are over half a million by now. Of all the machines I looked at, the Shopsmith was the only lathe-based one; all the rest were European tablesaw-based machines, heavier duty and much more expensive (think Felder and Robland).
At the time, I interviewed owners of all the machines we tested and learned what they liked most and least about their machines. Most had purchased their combination machines for the same reasons you are contemplating: They're economical, portable and versatile, and they get you up and running in a hurry. The main drawbacks they cited were that only one person can work on the machine at a time, changing functions is tedious, and you need to organize your work differently to avoid having to change so often from one function or attachment to another. And, in the case of the Shopsmith, the capabilities of the various attachments are generally lighter-duty than dedicated machines.
If space is a concern and the scale of your projects is likely to be small, this shop-in-a-box is one way of getting up and running quickly, and the deal you found seems like a good one. If it were me, buying for someone interested primarily in turning, I'd find a small dedicated lathe in the Jet 1236 class and maybe a bandsaw. The Shopsmith lathe function has a lot of accessories, nowadays, including special-purpose centers and chucks, but they are all proprietary, with the set-screw mounting system.
