$1500 energy tax rebate - beware!
Bill Mackey
>I don't know if this is the proper forum for this but I thought it would be good to spread the word about the much hearlded energy tax rebate. I am looking to upgrade a older heat pump in my house. I had a fellow over to give me an estimate and was shocked to learn that very few heat pumps will quality for the "up to" $1500 rebate. Apparently, there are three separate criteria that determine if an installation qualifies; a 15 or higher SEER rating, a minimum 12.5 EER , and an 8.5 HSPF rating (a measure of heating efficiency). All three criteria must be met. Problem is few heat pumps meet all three criteria except the most costly ones. The fellow said many people are installing a lot of equipment in expectation of getting the rebate and will find out to their chagrin that they don't qualify. As with any thing you get from the Government; if it is too good to be true then it usually isn't. If you are planning improvements to take advantage of the rebate, do your research beforehand.
