Shelving questions
Shelving questions
Shelving questions
Gary Evans Tallassee, TN
>Hi all,
I have a commission to build a set of shelves for a guy. Due to the construction details, I'm going to be joining the stationary shelves to the sides with blind dadoes. Any hints to shorten my learning curve? I've never done them before. I usually rout them all the way across the side and then trim with a face frame.
Also, some of the shelves will be moveable. Any tips on drilling the rows of holes for the adjustable support pins?
Thanks much,
Gary
Re: Shelving questions
Fred Davis
>stop rout them with your router and square up the end with a chisel.
I either make a template from 1/4" ply or masonite for the hole layout or even cut a strip of 1/4' masonite peg board with 1/4" holes.
If you going first cabin on the wood and finish , you might consider the peg hole cups that finish out the holes in brass and use the matching peg.
Costs more that way too.
FredD
Bill Tindall, E.TN
>Almost all my shelve units are built with blind dadoes and adjustable shelves. What's to say? Stop the router 1/2" shy of the front and notch the fixed shelf that fits in this dado. You can square up the end of the dado with a chisel. For paint grade you can do a through dado and glue on a face strip. I set the fixed shelves in about 1/16" from the unit's front. This way if you are off 1/64 it won't be noticed.
You can buy an expensive hole drilling jig for your task. I just drill the series of holes in a 1" thick piece of scrap, boldly label the bottom(to avoid screw ups), clamp or tack it to the vertical supports and drill with a hand drill to required depth. It all goes quickly so long as the bottom of the jig is positioned at the bottom of the shelf unit each time.
>Thanks guys,
It probably doesn't seem like a big deal if you have done a bunch of the blind dadoes. I have been a little spooked about trying them because several years ago a good friend of mine who is a shop teacher and a talented woodworker was working on a case with blind dadoes and singing the blues about how much trouble they were to get right. I seem to remember the words,"I'll never do this again!"
No choice on this one though, so I'll give it a shot on some scrap before I try it on the finish board.
Thanks again for the tips.
Gary
Shelf support method
Ellis Walentine, Host
>It sounds like you've gotten enough good info on the stop dados, so I'll skip to the shelf question. I like to make a drilling template from a rectangular piece of plywood the depth of the case. I gauge lines at whatever logical distance from the front and back edges. (If you're thinking of adding System 32 components at any point, such as doors, fall fronts, drawer slides, etc., make the front row of holes 32mm apart and set back 37 mm from the front edge. I prefer 5mm holes, which is the system 32 standard diameter, but 3/16" or 1/4" can also work.
Part of the reason for having both rows of holes in the same template is that this spaces the front and back holes uniformly, which becomes important when you try this next trick. I make a little router jig the width of the shelves and cut slots for a template bushing centered on the same front-to-back hole spacing. Then I rout grooves in the ends of the shelves to completely hide the shelf pins. This has another advantage besides a clean appearance: It keeps the shelves from sliding forward on the pins or rests and dumping their contents on the shelf below. It's a low-tech approach, too. Nothing to buy but the pins themselves.
My/His shelf support method - A Jig
Bricofleur
>I use the jig Norm Abram shown in several episodes of the NYW. It is simple to build and easy to use. The key is having a centre indexing line to make sure the front row of holes is equal to the back row.
The jig has 5/8" holes, 1" apart, and my router is outfitted with a 5/8" guide bushing and a 1/4" spiral carbide bit.
Good luck!
Best,
Serge
www.atelierdubricoleur.spaces.live.com
Alan Young
Ugh! Where were you a month ago?! :^)
Alan Young
>Next Media Wall project!
Alan
NickB in Eastern Mass.
>I'll leave the stopped dado question alone, but to echo others, 1/4" tempered MDF carefully laid out, then drilled on the drill press makes a great template (at this point, I think tens of thousands of holes have been drilled with the original template I made years ago). I did mine with 32mm spacing so I could use system 32 stuff. The one other thing, which may not be an issue for you, is making some registration pins so you can extend the effective length of the template. I turned a couple of pins, stepped at 5mm, whatever the diameter of my template holes are (made it a while ago), and then bigger, so I can overlap the template with the already drilled holes and maintain spacing. Very helpful when doing custom closet inserts.
Hope this helps,
Nick
