Re: Painting my house Question? (OT)
Glenn Madsen near San Francisco
>I'm in California, so take with a grain of salt anything I tell you. We have rules here that often differ from the rest of the country, and I don't want to argue what's correct or best. We get to follow the rules here...
My house is T-111 and stucco. Painting the T-111 BEFORE it gets cracked and loose is strongly preferred, but I understand you haven't that luxury. The folks who indicate that power washing needs to be let dry completely are correct. Here, that takes less than a week. My concern is catching the wash-off if your flaking pain has lead in it. It may not, but some of those houses are older, and yours may. Lead test kits are cheap and available.
A sander and a vacuum attachment with HEPA filter may take care of your sanding dust as well, and keep the power wash off-flow under control. Wear a mask...
The primer recommendations sound correct, regards oil/latex, etc. So does the recommendation not to skimp on paint. Find out who is the best manufacturer of paint in your region, and buy their product from a professional outlet. You'll get the best product, but you'll also be able to rent the best airless sprayer there for your job. THOSE are the best tools to come along for painters in the last 50 years or so. Purdy brushes. Good quality CLOTH drop cloths. And buckets, tape, sponges, wire brushes, caulk, and on and on and on.
If you do it right, it will not need doing again for at least ten years, and maybe longer.
Mine gets done more frequently because LOML wants a color change. ;-)
