Learned something about my saw this weekend
Lee Schierer - McKean, PA
>I have a Craftsman Contractor style table saw that is about 20 years old. This weekend I needed to tilt the blade 17 degrees to make some raised panels for a project I'm making. When I went to return the blade to 90 degrees using my digital angle indicator I noted that the saw was very difficult to tilt back and it wouldn't go to 90. It felt like I was going to break something to get the last 2 degrees of tilt out of the blade. I couldn't figure out how the stops could have moved. It took a couple of minutes peering through the various openings with a flashlight, but I finally noticed that the curved arc slot for the blade tilt lock was crammed full on the 90 degree end with sawdust. The accumulated sawdust had compacted so hard that the locking rod could not travel all the way it needed to allow the saw blade to return to the 90 degree position. The washers that rode on the surface would stop the sawdust from escaping as the rod got close to the end of its travel.
It was easy to fix with a slim screw driver to poke out the offending sawdust. Once the sawdust was removed, the saw would easily tilt to minus 2 degrees.
Lee
