Veritas - Innovation in Tools
What kind of nails? Multi Part question
Joe in a Cleveland Suburb
>Hello all.
I have two questions.
I am going to build a fence using typical borg cedar slats attached to PT 2x4 rails. I'm going to make a bunch of 8 foot sections, then attach to 4x4 posts set in the ground. The current cedar slats are nailed to the rails using some kind of rust proof nails that are spiral in shape. I am wondering, can I use my Port Cable round head 350 framing nailer for this? What kind of nails should I buy? I'm don't have much nail knowledge...
Secondly, my son, for his Boy Scout Eagle Project is going to make and install 20 Eastern Blue Bird boxes for a local park. These will be made out of cedar - if we can find somebody to donate the wood, might be PT though. Any reason why he couldn't nail these together with a PC finish nailer? I'd like these bird boxes to be built to last a while. Maybe he should use screws? What would you suggest?
Thanks for any input/suggestion!
Joe
Re: What kind of nails? Multi Part question
Anser to both questions
Lee Schierer - McKean, PA
>I would use stainless steel screws for both applications. Nails tend to pull out over time due to freezing and thawing, screws don't Steel nails will leave rust streaks on your cedar, stainless will not.
I've made a number of blue bird houses and prefer to use stainless screws wood screws I bought at the Borg. Speaking of the Borg and Eagle projects. Make sure he talks to the manager and makes it known the materials are for an Eagle project. When my son did his Eagle project 90% of the companies contacted donated the materials he needed.
Another wood you might find cheap and easy to get in your area is Eastern Hemlock. This wood will last 15+ years outdoors. Treated lumber is okay, but may be too smooth for the adults and young to get back out of the box and has issues with fasteners corroding. Rough cut hemlock gives a good gripping surface inside. Make sure he mounts the houses on posts covered with 4" pvc as raccoons tend to look at them as feeding stations if they can climb the poles. They don't seem to be able to climb 4" PVC drain pipes. I put a 2 x 4 or 3" landscape timber in the ground and slide the 4" pvc over it.
Lee
Answer to both questions
Lee
ans. to 2nd question
Bill Tindall, E.TN
>I have helped with this project in my area and here is what works based on a couple of decades of experience. Use the brad nailer to hold the pieces in place and then permanently nail with #4 galvanized nails, available anywhere. They will last as long as the cedar. We have done the project with cub scouts and the brad nailer holds the pieces in place while they drill pilot holes with hand drill and then add the nails. These little guys need all the help they can get nailing stuff. The pilot holes lead to their success. I made a jig for hand sawing the boards to length including the miter at the top.
We use cedar and the cost per box is not great.
Alternative *LINK*
>SS screws will do very well, but if you've got a fair piece of fencing to do, stainless ring-shank nails will do almost as well. The link is to McFeeley's where they sell SS collated nails from finish to clipped- head to full head. On their site you'll also find a compatibility chart that lets you match the code on each variety of the nails (A though H, I think) to your particular gun.
Nails
For what it's worth
>I put up some PT fencing recently and found some properly sized PT-rated galvanized nails at Amazon.com. The ones at HD/Lowes were either too long, or if they had the shorter ones, they weren't the ones made for pressure-treated wood. The galvization is thicker I believe. These nails are just the right length for the 3/4" slats to go into the 2x4 rails and went in amazing flast with my Porter-Cable FR350.
90% of the work was setting the posts and rails... nailing the slats went so quickly I felt something was wrong ;)
Happy Woodworking!
PT?
Alex Grigoriev
>I would not use PT for the birdhouses. Could be harmful for them.
I agree!
mdclor
