Correct order to do things
Doug
>I am putting on new stair treads and risers that are finished in oak veneer on my basement stairs. They simply go over the existing treads and risers. The new treads and risers are unfinished. Would it be better to stain these before securing them or after? The risers will be glued and the treads nailed. If I finish them first (we intend to stain them on the darker side), I will need to touch up the nail holes with filler and touch them up with stain. Is this better than trying to stain them once installed? The same question applies to the protective finish. What's the best order to do this in? Thanks.
Doug
Re: Correct order to do things
>How public are these basement stairs? Myself, I think I'd prefinish - easier to blend in nail hole repairs than to keep stain and finish off the sidewalls.
If I understand correctly what you're doing, you're going to run into rise discrepancies at the bottom and top steps, because the rise to the bottom step from the basement floor will be higher than the rise of all the other steps (except the top step) by the thickness of the new tread surface; and the top step will have correspondingly less rise to the floor of the house.
Code calls for variations of less than (if I recall correctly) 3/8", and less variation is desirable. I can testify from my badly cut first attempt at front steps that this DOES make a difference. We lived with my ignorance for years, but never happily - we had to warn people to watch it as they went down the steps.
Fred Davis
>In California , stair code is established by the State and it is specifically designed for blind people and will not tolerate the variance your quoting , not even close.
It seems to me that veneered treads unless covered in the walking area with something like carpet or non-skid rubber mating made for that purpose would not last very long, certainly the finish would go to hell in a hurry.
Your right about the discrepancy in the riser height, one end or the other will be out of rhythm which is why the riser height is not allowed much variance, none is the goal.
FredD
Doug
>So what is the best type of filler to use for the nail holes that can be stained and finished? I intend to use a finish that is used on gynmasium floors. Have been told it can take the punishment one can expect in a household staircase.
Doug
Fred Davis
>I don't know if it is the best , but I have been using timberMate filler for the last couple of years and I wish I had it years ago.
About any brand of filler with the right color match will work , though hardly any will stain the same as the adjoining wood.
As for the finish I am skeptical when they say it is as tough as gymnasium floors , because Gymnasium floor seldom get the outside grit that basement stairs would .
All wood stair treads need to be refinished from to time and I think the veneer will probably fail sooner , rather then later.
But that's just what I think.
FredD
