Build it rather than cut one down...
John in NM
>Most commercial exterior slab doors have a particle board core with wood edging to hold hinge screws and locksets. So cutting one down to the dimensions you mention will definitely not work. Given the small size, I don't think you'd be able to find a frame and panel door to cut down either.
I'd build it by making tongue and groove boards of the desired wood (deep tongue and groove, maybe 1/2" rather than 1/4", but then I live where wood tends to shrink more than swell). I'd either screw the battens on or clench nail them with old fashioned cut nails.
Depending on the time of year and whether you expect the door to shrink or swell, you might need to fit it tight in the jamb or leave it a little loose. You can probably guess better than I based on your local yearly climate (I've almost sworn off doing some kinds of joints in the summer - there's no way to avoid gaps in the winter. Do them in the winter here, and they look fine all year).
