Using higher wattage light bulbs - Dangerous?
Terry Alexander
>House is coming along.
Co-op is bringing power to the house on Tuesday.
We are doing our part to build and furnish "green".
Using low wattage fluorescent blulbs where feasible.
The bride wants 2 places with a lot of light.
The utility room (very small) and the hallway between the master bedroom and the kitchen.
We purchased 2 of those round white globe lights that have been around forever. I think our house from the 60's had them.
The package says to use a maximum of 60 watt light bulb.
Having said/typed all of that.
Q: Is it dangerous if we opt to put in a 75 watt or a 100 watt in this fixture?
As always...TIA for your valued advice.
Terry Alexander in West Texas.
Re: Using higher wattage light bulbs - Dangerous?
GalenV in Iowa
>Those small round glass enclosed fixtures are probably the worst type to put larger bulbs in. They would just get too hot. It will shorten the bulb life but worst case is too much heat against the ceiling and possilbe fire.
Trying to put in a larger compact flourecent thinking it is cooler is not a good idea either. The bases generate too much heat and most are not rated to put in an enclosed fixture.
Since those fixtures are cheap I suggest you get something else that will allow you to put in two bulbs or wire for more lights.
Galen
In a word
>yes
The more wattage, the more heat generated. The excess heat from the higher watt bulb will break down wires' insulation and other parts, especially in a globe as you describe. You can, however, work "green" and have more light by using Compact Fluorescent bulbs which take far less juice and are brighter. A 23 watt CF bulb will put out as much light as a 100w incandescent. You do want to check, however, to make sure the CF bulb can be used in an "enclosed" fixture.
Two things to remember: 1. The CF bulbs take a minute or so to reach full brightness. Flipping them on and off will prematurely wear out the integral transformer/starters in the bulb bases. 2. When burnt out, the CF bulbs must be disposed of like other hazardous waste; do NOT just put them in the garbage.
del schisler
>check on the fixture It will say max watage If it is 60 watt than use 60 watt not any more These have been lab tested for safty The way the sockets are built I sure wouldn't go for more wattage Heat and the wireing to the socket I have seen these socket's melted where the rivet is Than it is a lose conection Than you can and will have a Serous problum to where sparks may start and than next is flame probly than oh well not good been around this stuff for 60yrs back when knob and tube were used I am sure some of you remember those
>We ended up getting some globe type compact fluorescent bulbs as well as PAR 30 type bulbs. They work well in the enclosed fixtures. YMMV
It isn't just the fixture
Randy Johnson Connersville IN
>I have seen several cases where the building wiring got so hot from 100W bulbs in 60W max fixtures that the insulation cracked off.
GalenV in Iowa
>JL
Is that a joke?
PAR-30 in an enclosed fixture? I have seen downlight canisters that have to vent to attic and no insulation around, closed on exposed lens and typical downlight canisters that are open. How do they get by in enclosed? Forget what is used for submerged pool light.
Thought globe type CFL were used in open as well.
Is there a brand of each that allows them to be in enclosed fiture?
I know they are making fixtures that are pretty much enclosed for what I call the old round tube and not sure how that works.
Galen
Re: In a word
Kirk (KC) Constable
>I'll go out on a limb and wager that 98% of dead CF bulbs will end up in the kitchen trash can.
CF
>I put one bright CF and one incandescent bulb in each 2-bulb enclosed ceiling fixture. The incandescent is bright instantly and the CF is bright soon after. I like the quality of light of the mix.
Speaking of CF, I've been using the 150W and 200W equliv CF bulbs in my garage shop ceiling fixtures (simple sockets). Last week I found a 300W equiliv CF at Home Depot. The thing is HUGE, uses a standard base, and does in fact put out a lot of light (after it warms up). It uses approximately the power of a 60W incandescent bulb. I think I go back for some more.
>Galen, read the message again. We got some globe types AND some PAR 30s. The Par 30s went into my track lighting systems for my shop and a can fixture for my basement stairs. The globe type went into a sealed unit that I put below the stair rail on the stairs to the basement.
I went with CFL because they are a LOT cooler. We also put some "decorative" CFL bulbs in the bathroom fixtures - they are the kind that look like regular bulbs rather than CFLs. We use one incandescent bulb in each bathroom fixture because it takes a bit of time for the CFLs to come to full brightness.
On A Bet
>The odds are way in your favor which means that the good folks in the Ohio River valley can expect to see the residuals showing up in their drinking water any time now.
Re: CF -- NOT FOR USE IN ENCLOSED FIXTURES
David Hammelef
>Better be careful. Last I saw you should not use CF in enclosed ceiling fixtures. My guess was heat build up but I don't know why.
CF are a dieing industry. They have so much wrong with them for so little gain. They have a small window of life but the price for LED's is dropping and then its game over for the CF.
Of course the green movement has a problem with LED's they run on so little power, they are afraid light pollution will become a big problem.
Bought an 8 pack of LED night lights, wife has one in most rooms and hallways, they replaced the 2 in the bedrooms and the 8 use significantly less power than the 2 did.
Daughter has an LED light for reading at night in bed --- plugs into the phone outlet for power.
Me English must be bad :>)
GalenV in Iowa
>I must have read things wrong..
Tried to use more CFL as city has given out free for the last two years. Found in most cases if I had a 60W incandescent I had to use a 75W equivalent CFL to get the same lighting. Still a power savings.
Did the same in bath with one out of three still incandescent.
Basement lights heading to my shop area seems more like a match stick light till they come up to full brightness but I burn more power when I turn on lights over tools.
I figure the cost saving in the rest of the house lets me use more power in shop so really do not save any coal for the city power plant!
They just raised the rates anyway to offset anyones conservation methods.
Galen
Re: On A Bet
GalenV in Iowa
>Which will give you more pollution?
1. Mercury in compact fluorescent lights
2. Mercury outboard motors on the lakes and rivers
3. Mercury automobiles rusting in the ditch
Galen
Jay Lombardo
>Please do not use higher wattage bulbs. The heat will make the insulation on the wires dry out and crack off in the junction box. The socket where it screws in will also become brittle and the terminals in the socket will become loose and start to arc, arc means sparks, sparks mean fire. I have repaired the damage caused by 100W bulbs HUNDREDS of times. Go to change the fixture, drop it down, pull the wires out of the box, and all the insulation from all the wires crumbles to the floor. That means you got lucky and found it before the arcing started, If you don't then it is just a fire waiting to happen. Seen it way too many times.
Jay
YouForgot
>Heavy Metal Head-bangers on Mercury Records.
Alexander Grigoriev
>In my experience, low cost no-name CFL (for example, those sold by IKEA) don't last. GE don't do, either. Sylvania do last quite long.
Jim Dillon
>Terry,
Thanks for posting this OT question. I have learnt a lot from the responders and plan on making some changes. I recently replaced some 60W bulbs with 100W bulbs, even though the sticker said max 60W. Did it because I only had 100W bulbs left in the closet. While I appreciated the extra light, at first chance I will pick up some 60 watters and replace my 100 watters. Also trying to change to CFL, at least until LEDs become a less expensive, and more colorful option.
Jim
